2012 A3 8P SRS Airbag module location ?
Hi I am taking apart a 2012 a3.
I need to get my module out to be reset.
Does anyone happen to know the location of the computer?
thanks
thanks
thanks everyone for the rush of replies...
If anyone wants to know its located right under the ac controls in the ash tray area..(mine doesnt have an ash tray but that area ) .
you need to remove the whole plastic center console then you will see it..
Here is a write up - follow it up to the console is out then look for the module tucked away right at the back. there are 3 10mm nuts that hold it down, remove them and it will slide out through the drivers side with the wiring harness attached.
audiretrofit-rs4startbutton - Audi Retrofit
andrew.tt
01-31-2007 05:52 PM
mdillian3690
06-18-2003 11:19 AM
KC~Audi
07-09-2001 09:51 AM
