8P Quattro Questions
Hi guys,
First post here! I am hoping to get into an A3 quattro for my next car, but am having difficulty clarifying a few things (have done numerous searches on here, VW Watercooled, Audizine, VW Vortex etc).
1) I will want to lower the car by 30-50mm. Can I use the stock shocks with springs of this height? I 100% understand that it's best to do springs+shocks all at once, but depending on how much I end up paying for the car this probably wont be in the budget for a year or so. Id rather do the springs now, and then do the shocks if/when they need replacing
2) Can I use springs designed for an S3 or Golf R on an 8P A3 quattro? (my understanding is that the FWD sportback uses different rear springs to the AWD version which rules them out)
3) Is a downpipe + hi-flow cat + panel filter enough for a stage 1 APR? Are there any other
Hi guys,
5) Would ideally like to take the car for a pretty comprehensive service after purchasing. What are some common problems that I should look to be addressed? Preliminary research says that intake buildup is notoriously bad on the EA113s?
6) Will a headunit designed as a direct replacement for a MK5/MK6 Golf (and Polo/Amarok/Jetta etc) fit into an 8P (both with the physical cavity and CANBUS)? They seem to be significantly cheaper than buying either an A3-specific unit, or an Audi adapter+fascia kit+head unit
Any help would be greatly appreciated, as I've been able to find answers to the rest of my queries but these are the final loose ends that I want to tie up before purchasing.
Thanks!
To answer question 3. You dont need to change anything for a stage 1 but saying that what you have is good too.If your in Brisbane go to BPS Auto at Cleveland, i have heard only positive things from them and cheaper than APR.
95ninety
10
09-26-2006 04:27 PM
Turbo_Whip!
06-16-2006 12:27 PM
AYtheory
12-11-2005 11:57 PM
