A3 Sirius question - would really appreciate help
Just bought a 2007 A3. Wired for Sirius, but lacks the module. Dealer says the module model number is 8E0 035 593 Q with a price of $595. I know these types of questions have been posted millions of times, and I apologize for being millions+1, but I can't find the specific answer. Are there other models that will work instead of the Q version? If so, which one(s) do you recommend? Thanks for any and all help.
You can use any reciever revision (although I'd bypass the original 8E0 035 593/8E0 057 593 (letterless) receiver.
As you may know there are both XM and Sirius receivers. Since Sirius-XM recently "re-merged" their programming so that channels now match between the two services your main choice is based on the programming differences--one has baseball and the other football, etc.
Once you've decided on a service you can get a receiver. Because you have an '07 you may have either a single- or dual-lead antenna. Receivers also come in either single- or dual-antenna connector models. You can use either but you have to make the receiver happy for it all to work right. If you have a dual-lead antenna and a single-connector reciever you just ignore the antenna lead that doesn't match the color of the receiver's connector. If you have a single-lead antenna and a dual-connector reciever you'll have to get a splitter to make both connections. Otherwise both are singles/duals and everything matches.
FYI: Sirius reciever revisions: D, F, H, L, N, Q
XM reciever revisions: E, G
Dual antenna connections: D,E,F,G
Single antenna connections: H,L,N,Q
Manufacturing cutover from dual to single antenna for the A3:
VIN WAU..8P..7A105278
A good source for recievers is e-Bay. Search on Audi Sirius or Audi XM.
Outstanding reply - thanks. Based on the VIN, mine is single antenna. Given that, is there any advantage among the H,L,N,Q modules? I already have a Sirius subscription (this A3 replaces one that sacrificed itself when a car pulled out in front of us!), so I'm just going to transfer the account.
Again, thanks.
Again, thanks.
I would think that any of them would be sufficient. Also note that VW used the same receivers in their cars until they switched to an integrated receiver.
I have seen messages from owners who bought a receiver that the subscription had expired that wouldn't reactivate. That may be the reason they revise the units. If you go with a used unit I"d make sure that I could return it if it didn't work.
Question here...
Dealer gave me a used 4E0035593A SW: 4E0910593C XM receiver.
I have a single antenna on the car and this receiver has dual.
Any idea what the part number is for the splitter? I have searched all over the internet and can't find it.
Thanks in advance for the help.
http://www.amazon.com/gp/aw/d/B0002GOH42
You may have to trim the plastic on the connectors to get them to fit.
GOT ONE AT We sell genuine Used auto parts, For car and truck. At a fair price. ? USEDPARTSRUS FOR $100 CHECK THEM OUT
GoodMatt
European Discussion
12-18-2008 08:15 PM
repeater
Audi 100 / A6 (C4 Platform)
10-30-2003 02:00 PM
