Audi A3 1999 1.8T - Starts when cold then dies when warm
Model: A3
Year: 1999
Engine: 1.8T AGU-053879
Chassis: WAUZZZ8LZXA011786
Not sure if this is the best forum to post this on but I'm having trouble getting any responses.
I've attached a link to a youtube video I took showing the problem a bit clearer:
Basically it starts, runs for about a minute and then shuts off and won't start again.
I've plugged in a VAG-COM and this is what it gives me:
Thanks in advance for any help
Year: 1999
Control Module Part Number: 06A 906 018 AQ
Component and/or Version: 1.8L R4/5VT MOTR AT D03
Software Coding: 04030
Work Shop Code: WSC 06313
2 Faults Found:
16487 - Mass Air Flow Sensor (G70): Signal too High
P0103 - 35-10 - - - Intermittent
01262 - Solenoid Valve for Boost Pressure Control (N75)
26-10 - Output Open - Intermittent
VAG-COM Version: Release 409.1-S
Control Module Part Number: 01M 927 733 ET
Component and/or Version: AG4 Getriebe 01M 4576
Software Coding: 00000
Work Shop Code: WSC 00000
1 Fault Found:
00518 - Throttle Position Sensor (G69)
16-10 - Signal Outside Specifications - Intermittent
2 Faults Found:
1 Fault Found:
