Looking at 2008 A3
Looking at 2008 A3
Long time browser first time poster.
I am going to look at an 08 A3 2.0T and was wondering what I should be on the look out for.
Car has 116k miles on it which to me seems low (I currently have an '00 TDI) but I do not have an idea of how long these things last/their long term reliability. How many miles can I expect it to last with consistent preventative maintenance?
What are the specific things that I should ask about? Basically i'm like every other guy who doesn't want to have to replace a transmission after owning the car for 3 months.
Thanks for the help
Thanks for the help
I wouldnt
Thanks for the help
Thanks for the help
I just got an 06 with 95000. After two weeks the high pressure fuel pump went out and that meAns the cam is toast too. Didn't know this was an issue until now. Audi denied me any help for this common problem and now I need to come up $2800!
Thanks for the help
Thanks for the help
Hi all, new here, researching 2006-2008 A3s. Anyway, Justin, I've seen mentioned in some places that the hpfp has an extended warranty VWVortex.com - Warranty extension letter from Audi for intake camshaft, cam follower, fuel pump
If the OP wants we could try and create a buyers guide type thread for the A3. From my research it looks like the following are things to keep in mind:
1. Timing belt should be done at 100,000 miles. (It can be a $1500 service with the pump change)
2. Water pump should be done at the same time as the timing belt.
3. Ask if they've had pistons and rings changed.
4. If have they had their PCV changed. A rough idle can be a sign of a bad PCV
5. Related to 3 and 4, have they had their intake cleaned of carbon deposits if needed.
6. Ask if they are burning oil.
Unfortunately it seems to me that lots of the above is not stuff that you would learn during a pre purchase inspection but rather if a nice and diligent owner knew this about their car, it would allow you to gauge costs for maintenance. Me personally, I'm trying to find one with belt and pump replaced and going to factor cleaning the intake and a new PCV and time into cost(though I will do then myself).
Caddie3.2
Q5/SQ5 MKI (8R) Discussion
10-17-2014 03:50 AM
Sneaky S4
09-17-2007 09:40 AM
hermitage1
01-07-2003 04:30 AM
Gnowknayme
11-02-2002 01:43 PM
