2015 S5 driving modes causing problems
#11
Anyway, my point was made in context to trying to give some help to Airtomud's OP regarding torque limits on clutch components.
From the home of Fact and Fiction:
https://en.wikipedia.org/wiki/Direct-shift_gearbox
It is of course the theoretical hand-off time between input shaft 1 and input shaft 2, and only on upshifts, and only on a pre-selected gear (obviously upshifts are always pre-selected). It is also torque managed - meaning put it in D mode, accelerate softly, and the upshifts are much faster than full throttle in S mode. Down shifts are slower, and if the downshift is not preselected much slower.
It was a management directive to develop the fastest shifting transmission,but that brings engineering compromises on torque limits, as the faster the shift speed, the great the dynamic torque multiplier effect. In my comment to Airtomud, I mistakenly said static when I meant dynamic torque.
But the directive was probably due to greater fuel / emissions efficiency to minimise average RPM in drive cycle certifications than to reduce track times
I suspect shift speeds in both the DQ and DL transmissions may have been slowed (relative to torque load at the change point) over the last few years to improve reliability, but that is just a guess.
#12
Yeah I didn't think it was 8ms, but neither does F1 use dual clutch transmissions. F1 uses seamless gearboxes. They shift without a clutch. They cut ignition briefly while the dog rings disengage from one gear and bind to the next gear resulting in only 0.3ms of power interruption. The transmission has a single clutch that's operated manually via two buttons on the steering wheel and is only used to start and stop and in an emergency. The first button gets the clutch right to the bite point and the second button gives the driver fine control over engaging the clutch, so there is some driver skill involved in getting out of the hole. Dual clutch transmissions are prohibited by F1 regulations.
Seamless Gearbox
The dog rings must have some interesting geometry on the "teeth", because they must be partially engaging/disengaging at the same time, so there has to be some "slip" for this to happen. I hadn't read 0.3ms, but I guess any cut at all keeps it from being a CVT and within the regulations. Impressive engineering - the tolerances in machining and McLaren's ECU must be crazy. But then they don't last too long.
F1 moved to a single stage clutch system this year:
https://www.formula1.com/en/latest/t...t-returns.html
#13
#14
Actually, after looking at some specs, Glisse appears to be correct in one scenario. The DL501 upshifts in 8ms if the next gear is already preselected on the alternate gear shaft. That's not the average shift time, though. For upshifts the average is 50ms I believe if I remember correctly and for downshifts due to the required rev matching it's around 800ms I believe, depending on how freely the engine revs. I believe downshifts on the RS4/5 are faster because the engine revs a lot easier. Same for the R8, but it has a different variant of the S-tronic.
#15
But none of this an issue for the OP with his manual transmission - just has to control the urge for burnouts and stock up on clutch packs
#16
Yep, that's why I still own my RS5 and don't miss a manual transmission in the slightest.
01Rosco
11-06-2009 10:02 AM
dbise
03-04-2009 01:20 PM
maggio
01-17-2004 03:22 PM
