Audi A5 / S5 / RS5 Coupe & Cabrio (B8) Discussion forum for the B8 Audi A5, S5 and RS5 Coupe and Cabriolet Model years 2009 - 2017
A5 convertible top care
Old 07-29-2012, 06:59 AM
447debbie's Avatar
Default A5 convertible top care
What have you used to protect your convertible top? I have a 2011 A5 Teak Brown Metallic Cabriolet with a brown convertible top. I'd like to put some type of cleaner and protectant on the top but I'm not sure what to use.
Old 07-29-2012, 11:19 AM
Ultimate Keyboard Warrior
Force-1's Avatar
Convertible Top Cleaning Kit
Old 07-29-2012, 09:27 PM
sharding's Avatar
I use Raggtopp. 303 has a product that is supposed to be pretty good too. I've never used the Griot's product Force-1 linked too, but I have a lot of other stuff from Griot's and have overall been happy with it.
Old 07-30-2012, 05:46 AM
DHH
DHH's Avatar
I've had good results with RaggTopp. Good demo video here:
http://www.autogeek.net/covtopplas.html
Old 07-30-2012, 04:12 PM
447debbie's Avatar
Thanks. I'll check it out.
Old 07-30-2012, 04:14 PM
uberwgn's Avatar
RaggTopp would be a good place to start and is approved by Haartz.
Old 07-31-2012, 01:59 PM
Jon'sS5's Avatar
Default Protectant on a new top?
Sounds like a great color combination. I have a brown top on my Glacier White and really like it.
I hear lots of good things about 303 protectant. However, I asked the technical team at 303 a question regarding application, and got this detailed reply. 2011 is pretty new, I would think.
Synopsis: They do not feel a new top needs protectant.
Here is the reply:
HI Jon, thank you for the inquiry about your personal vehicle.
It the topping is “new” it does not need to be treated with anything, nor is doing so recommended. This applies to ALL outdoor fabrics.
Here’s text which will explain. Also answers your question about temperature, I believe, but if you have any questions after reviewing the following, please contact me.
Thank you for contacting 303 Products, Inc.
ALL* outdoor fabrics, INCLUDING automotive fabric convertible topping, come new
with a protective “fluoropolymer” fabric finish put on at the mill. The reasons
for this protective chemical finish are THREEFOLD:
1) To resist soiling. Treated fabrics stay cleaner much longer before soiling
(than untreated fabrics), and clean up easier when finally soiled.
2) To protect against indelible stains. Stains that otherwise would be
indelible, are usually quite easily removed from fabric because of this finish.
3) To provide and maintain water repellency.
No matter what type of outdoor fabric you have or what company manufactured it,
the protective fabric finish will diminish over time. Eventually routine care,
“cleaning and re-treating”, is required. An informed person will know when to
do this by observation....noticing the lessening and, if not done then,
inevitably the complete loss of water repellency. It is best to clean and
re-treat when diminished water repellency is first noticed. Don’t wait until
there’s no water repellency at all.
Diminishing water repellency is also the time at which when one starts to notice
soiling. Diminishing water repellency....often accompanied by the onset of
soiling….these are indicators that it is time to clean and “re-treat” the
outdoor fabric.
So, should one “treat” outdoor fabric when it is new? NO. It is not
recommended or necessary.
Old 08-07-2013, 09:04 AM
delliot's Avatar
Default 2010 A5 Cab
OK, I'm a new owner of a 2010 A5 Cab. When I wash the car should the water bead up on the roof? I'm thinking it should, so I'm looking at some king of sealant. I've used 303 in the past so I was leaning that way.
Anybody else used it?
Thanks
Old 08-07-2013, 02:59 PM
Boostedws6's Avatar
Thanks
I haven't used 303 but raggtop works well from my experience. Is your top still repelling water or does it soak right in? If I spray my top with water, it beads. I have to saturate it for it to soak in.
If that isn't the case with yours, get it addressed sooner than later.
Old 08-12-2013, 07:40 PM
delliot's Avatar
yeah, there's no beading what so ever... guess I'll treat it this weekend.
Quick Reply: A5 convertible top care
