Audi A5 / S5 / RS5 Coupe & Cabrio (B8) Discussion forum for the B8 Audi A5, S5 and RS5 Coupe and Cabriolet Model years 2009 - 2017
Manual Transmission Fluid specs
Old 05-04-2012, 09:50 AM
jamilkhan80's Avatar
Default Manual Transmission Fluid specs
I'm trying to drain and replace my manual transmission fluid. Does anyone know what kind of transmission fluid my car would take? I'm having a hard time identifying it. Also, would you know how much fluid I would need if I do a drain and fill.
I have a manual 2008 S5.
Thanks,
J
Old 05-05-2012, 09:53 PM
32spoke's Avatar
go to liquimoly website and enter your vehicle info
oils can be ordered by napa auto parts stores
you trans oil is 75W90 GL4+ synthetic. DO NOT use GL5!! if you do, make sure it's safe for "yellow metals" or synchros that get f*cked up by the non slip additive/friction modifier placed into GL5 fluids. Redline oil makes a 75W90 GL5 NS. I think it would work, but I'd contact redline to verify/consult with a technician.. it takes 3.8 liters
diff oil is 1 liter same fluid GL4+...
Royal purple may make some
motul as well.
Old 05-06-2012, 05:06 PM
Beakerz's Avatar
Does the above information apply to the manual transmission in the A5 as well? Someone told me that it's the same exact gearbox, but I don't know for sure if that's correct or not.
Ben Wilson
TT (Mk2) Discussion
06-17-2019 01:37 PM
deankal
05-23-2012 11:53 AM
BAEL
Audi A3 / S3 / RS 3
10
02-15-2008 10:40 PM
jerobean
10-16-2006 04:26 AM
wab
07-23-2006 04:18 AM
Quick Reply: Manual Transmission Fluid specs
