Oil consumption test denied
#22
good info and thanks for keeping us updated
- I just had the oil changed (MY 2010) at an Audi dealer and wanted them to do an oil consumption test but they said to bring it back when it shows low oil..? I'm sure they topped it off with as much as they could put in.
#23
you have a dipstick? Check it yourself
to ensure they didn't overfill it. Not that you would use an oil sucker to lower the oil level below full….
#25
Got car back yesterday.. New pistons and rings. Drove 115 miles and used 1/3 quart of oil. Went to dealer this morning they said it's because the engine was dry after rebuild. They topped it of with oil and said it should be fine now......we'll see!
#26
rings may not seat without break in oil.
At the factory the cylinder size and crosshatch and piston and ring specs are much more tightly controlled than the dealer…if the cylinders were glazed or the original piston/ring combination poorly seated for whatever reason, the rings may take awhile to seat, if ever, using synthetic oils.
All this is conventional wisdom, of course, but using a good synthetic break in oil such as amsoil break in oil will generally help. For amsoil, the break in oil is kept no longer than 1000 miles. You can gauge the break in by measuring leak down or vizing the exhaust ports (complicated to view exhaust ports of course) during the break in period. From your perspective as long as the oil usage drops quickly, I'd say within 500 miles, you're probably ok.
AMSOIL Break-In Oil (SAE 30)
There are other break in oils of course, YMMV as they say.
#27
Any news on this? Did the fix work?
Also, does this oil consumption problem only occur for 2011 and older cars? i.e. - has it been fixed for 2012+ cars?
auditron
A6 (C7 Platform) Discussion
03-16-2013 04:36 AM
VR_Life
Audi Original "S" Cars
06-20-2005 12:03 PM
VR_Life
06-19-2005 01:41 PM
sidespar
11-07-2002 07:24 PM
