Audi A5 / S5 / RS5 Coupe & Cabrio (B8) Discussion forum for the B8 Audi A5, S5 and RS5 Coupe and Cabriolet Model years 2009 - 2017
Wheels Tires and springs
Old 08-18-2011, 05:34 AM
patrooper's Avatar
Default Wheels Tires and springs
Im planning on putting on my S5 cab 20 inch DPE scp sc wheels with 275/30 /20.
I want to lower 1 inch rear. Looking at H & R sport springs is this proper?
Old 08-18-2011, 08:28 AM
mop1.8t's Avatar
H&R sports will lower 1.3" front and rear and H&R OE will lower 1" front and rear and retain a near oem ride quality. I am running OE's with 20x9.5.
Old 08-23-2011, 06:53 PM
sparkster's Avatar
Default Did you have the sports package prior?
Wondering if the OE springs will still drop 1" for folks with the stock sports springs?
Your car looks AWESOME by the way!
Old 08-23-2011, 07:00 PM
mop1.8t's Avatar
Thank you sparkster...appreciate the compliment Yes, the drop is based off of the oem sport spring. I got right at 1" rear and just under 1" front from oem s-line. Its plenty unless you want the slammed look.
Old 08-24-2011, 01:35 PM
DDowS4's Avatar
Also consider the KW adjustable spring set, a little more expensive than H&R but the adjustability is well worth it. I put it on my S5 cab a few weeks ago and am loving the ride. I just took the GM from my Audi dealer for a spin a he was impressed.
Old 08-24-2011, 02:31 PM
DDowS4's Avatar
Here's a source:
http://www.amimotorsports.com/store/..._detail&p=7300
Alternatively you can order the MTM branded set, which I did for a whole lot more $, but it was all KW - even the box.
Old 08-24-2011, 04:47 PM
RSTREV's Avatar
DPE is a great choice ask the guys at DPE they should be able to help you on that and I love the dog!! Had a Dobie for years..
Old 08-24-2011, 08:03 PM
sparkster's Avatar
Default That is what I am looking for
Thanks for the info, wasn't so sure on this, but that is exactly what I am looking for. I currently have H&R Coilovers for my B5 and as much as I love them, it was a set it and forget it kind of deal over time, i have adjusted them maybe three to 4 times total, only cause the initial install was too high, then I slammed it too much, then i wanted to adjust it for the winter... but then i just left it being that it isn't the easiest job to adjust them all the time (especially with our salty Northeast).
I also like the existing stock sport ride - so don't want to go any stiffer in terms of spring rates.
Old 08-25-2011, 03:58 AM
patrooper's Avatar
Thanks, I'm buying the wheels from 1sicks5. This is my 3rd dobe. Alas probably my last although this one will be with awhile he is only 3. There good dogs only if u get them reputable breeders.
brucepancake
A4 (B8 Platform) Discussion
01-30-2017 03:01 PM
ervin86
08-27-2010 06:33 PM
rbella4
07-26-2001 05:04 PM
Quick Reply: Wheels Tires and springs
