09 4.2L S5 Front Crank Seal Charge $$
Pretty tight on the S5 too.
You might want to have them put in a new voltage regulator; the brushes generally wear by 140K miles and they're spot welded pigtails. If you're going to keep the car more than another 30K miles. Alternator easy to get to with front in service position.
Check/replace Serpentine belt and idlers/tensioners if you still have the original one(s) in there.
I don't know what the service interval is for the water pump on the chain-timing 4.2 engines is, if any, but the timing belt engines had the water pump and thermostat changed out every time the timing belt was serviced. You might consider changing out the water pump if it's up front and now driven by the serpentine belt.
PM:
My wife and I drive a 2004 S4 4.2L Avant. If you are privileged to have a timing chain in your S5, it is far better for you to be in control of when that component is maintained than the opposite. Your thought about having Audi service check out the timing chain and tensioner is spot on. We did not move quickly enough and a chain replacement as a repair is very expensive, indeed. Good thinking! IMHO.
Yeah, the PO issue is always a good thing to check.
Might have the car gone over thoroughly since it seems you intend to keep it to 200k miles. OTOH, that's what I intended to do with my 02S6 at 147K miles...a minor rear ender into a Toyota Highlander however upended that intent when the insurance company totaled the car. Sooner or later you get to the point where repairing a minor collision ($6K-15K?) approaches the value of the car and you're out of luck regardless of the car you've taken with the car. At 111K things are wearing out, alternator slip ring brushes, starter motor brushes, fuel pumps (you HAVE changed the fuel filter, right? Audi has no recommended time/mileage for that puppy IIRC), charcoal canisters, various rubber/plastic bits under the hood. Heater hoses and radiator hoses are lifetime bits, but lifetime is the lifetime of the part, not the car's useful life, LOL.
Some great suggestions there D.C.
I'm all for all of the pro-active preventative suggestions being offered;
- cam chain tensioners (or timing belt replacement)
- water pump
- fuel filter
I always buy used cars (last new car was 1983 lol) and I'm always ahead of scheduled/routine maintenance even though I have no idea of how long I plan to keep the car. It gives me peace of mind and if it happens to be overkill - so be it. If I do sell earlier then planned, I believe it's a great selling tool over others that may not be so diligently maintained. However, I routinely keep my cars for a fairly long time - normally 7 to 12 years. Hence the pro-active posture.
- water pump
- fuel filter
- water pump
- fuel filter
- water pump
- fuel filter
LOL...if you get away with $2,000 a year maintenance
i am like you in regards to keeping vehicles upwards of 10 to 12 years. Preventative maintenance is a big factor and i am OCD when it comes to my vehicles. I do have knowledge under the hood and am seriously considering tackling the job myself, but being this is my first Audi is my only drawback.
