09 4.2L S5 Front Crank Seal Charge $$
#11
If you had a timing belt (that car has timing chain IIRC) I'd say consider doing that early but since you don't....
You might want to have them put in a new voltage regulator; the brushes generally wear by 140K miles and they're spot welded pigtails. If you're going to keep the car more than another 30K miles. Alternator easy to get to with front in service position.
Check/replace Serpentine belt and idlers/tensioners if you still have the original one(s) in there.
I don't know what the service interval is for the water pump on the chain-timing 4.2 engines is, if any, but the timing belt engines had the water pump and thermostat changed out every time the timing belt was serviced. You might consider changing out the water pump if it's up front and now driven by the serpentine belt.
#12
Yeah, interesting that carbon buildup on DI audi
Right now I really don't give a dam because I have two leased B8 cars and a port-injected BMW M3...but sooner or later I'll have to change out the cars and most cars today are DI...but only BMW and Audi seem to have the carbon buildup problem.
#13
I like this guy. He's nailed the issue of carbon build up for the VAG and some of the options available.
Since I plan on keeping the car for a lot of years, I'm leaning towards removing the PCV's and plumbing in a nice catch can set up.
I haven't researched the topic in depth yet and if that process would cause any sort of codes coming up which would prevent me from passing emissions test in my area.
#14
It's not the codes but rather the oil contamination and shortened oil change intervals. Back in the days before PCV oil got contaminated a lot faster than after PCV was mandated. Not many emission regs resulted in benefits to the customer, but PCV was one in the sense of oil stayed serviceable longer. Another bennie was leaded gasoline, FWIW....exhaust systems lasted a LOT longer and so did spark plugs.
#15
I have a catch can installed on my Escalade and will put one on my next vehicle if it is a DI engine. Even in non-DI engines the valves don't get gummed up but the throttle bodies usually do which affects drivability as well.
I think a catch can would only cause a problem for passing emissions if you live in a state like CA. They don't like anything that isn't stock and sometimes don't even know what an EO is for a CA certified aftermarket part.
#16
A catch can by itself won't solve the problem
That's exactly the problem on why DI engines have carbon buildup problems that conventional fuel injected engines don't. The fuel that used to be injected at the back of the intake valve constantly washes it. Now you have oil vapors settling on a hot intake valve with no washing occurring and over time it builds up into what he showed in his video.
I'd be more likely to install a methanol/water injection system to keep intake valves (and combustion chamber!) deposits at bay. They've been around for decades and work well. BMW has even used it on one or two of their current vehicles/engines as I understand it.
#17
MY bad. I don't plan on deleting the PCV system when/if I do a catch can install. Sorry about that guys.
I wish there were viable hydrogen cleaning facilities in North America. I've seen some great things resulting from that carbon cleaning process which seems to be quite popular in the UK.
FourDs
53
06-08-2006 05:40 PM
veryfastS4
25
02-18-2004 10:59 AM
