A5 2014 Warning "ECP" + orange Engine flashing
Re: 2014 Audi A5 2.0 AWD with 9700 Miles
Last night while driving home 4am, orange warning light "ECP" came on. I could feel my car sort of jerking as I accelerated. I managed to drive 30 miles home, but as I got close to home, I could smell gasoline, and a lot of fumes coming from the exhaust. The last thing i did was a gas fill up, but I securely closed gas cap.
Today I connected VAG COM. this is what the printout looks like...
Part seem to indicate Ignition coil, i think ????
" Part No SW: 8K5 907 115 J HW: 8K2 907 115 L "
Has this happened to anyone else with A5 yet?
Does anyone know if this is covered under warranty?
I found this video on Youtube to replace ignition coils
Googled the parts, looks like a $50 fix.
Can anyone please confirm, or let me know if they see anything else on VAG Printout. Thanks.
Sunday,24,August,2014,14:33:22:04118
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.2.0
Data version: 20140212
VIN: WAULXXXXXXXXXXXX License Plate: XXXXXXX
Mileage: 15670km-9736mi Repair Order: Repair1
Chassis Type: FH (8R0)
Scan: 01 02 03 05 06 08 09 15 16 17 19 26 36 42 44 46 52 53 56 5F
62 6C 72
VIN: WAULXXXXXXXXXX Mileage: 15670km/9736miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
26-Auto Roof -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (DET-CPMB) Labels: 06H-907-115-CDN.clb
Component: 2.0l R4/4V TF H09 0002
Revision: ECH09---
Coding: 622A0013242600062000
Shop #: WSC 29698 001 1048576
ASAM Dataset: EV_ECM20TFS0118K5907115J 001003
ROD: EV_ECM20TFS0118K5907115J.rod
VCID: 3979DC81B84984D69C9-806C
8 Faults Found:
10426 - Fuel Pressure too Low during Cold Start
P053F 00 [101] - -
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 15679 km
Date: 2014.08.24
Time: 13:32:55
2838 - Fuel Rail/System Pressure
P0087 00 [175] - Too Low
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 15625 km
Date: 2014.08.24
Time: 02:27:59
4601 - Cold Start Idle Air Control System
P050A 00 [101] - Malfunction
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 15679 km
Date: 2014.08.24
Time: 13:33:08
10203 - Random/Multiple Cylinder Misfire Detected
P0300 00 [175] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 15625 km
Date: 2014.08.24
Time: 02:27:54
10591 - Cylinder 1
P0301 00 [101] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 15679 km
Date: 2014.08.24
Time: 13:33:00
10593 - Cylinder 3
P0303 00 [175] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 15625 km
Date: 2014.08.24
Time: 02:27:54
10594 - Cylinder 4
P0304 00 [237] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 15679 km
Date: 2014.08.24
Time: 13:32:53
10205 - Cylinder Disabling
P130A 00 [040] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Mileage: 15625 km
Date: 2014.08.24
Time: 02:27:57
Readiness: 0000 0000
62 6C 72
Revision: ECH09---
8 Faults Found:
P053F 00 [101] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 15679 km
Date: 2014.08.24
Time: 13:32:55
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 15625 km
Date: 2014.08.24
Time: 02:27:59
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 15679 km
Date: 2014.08.24
Time: 13:33:08
P0300 00 [175] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 15625 km
Date: 2014.08.24
Time: 02:27:54
10591 - Cylinder 1
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 15679 km
Date: 2014.08.24
Time: 13:33:00
10593 - Cylinder 3
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 15625 km
Date: 2014.08.24
Time: 02:27:54
10594 - Cylinder 4
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 15679 km
Date: 2014.08.24
Time: 13:32:53
P130A 00 [040] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Mileage: 15625 km
Date: 2014.08.24
Time: 02:27:57
P053F code with rough start up
I was wondering what the fix was for this repair? I have a 2015 Audi A4 and I have the exact same codes right now that keep coming back especially P053F. Runs great except when you first start it up in the morning or after work.. I replaced the HPFP a year ago due to no start intermittently. Now I am having rough start up issue. I tried a new in tank fuel pump and fuel line pressure sensors already. I pulled the timing cover and checked the measurement between the two timing marks and I was at 126.4 mm. I only have an OBD 2 scanner so any help,would be appreciated.
Ed@mtl
10-19-2004 04:10 PM
Crispy
08-03-2001 10:53 AM
