Audi A5 / S5 / RS5 Coupe & Cabrio (B8) Discussion forum for the B8 Audi A5, S5 and RS5 Coupe and Cabriolet Model years 2009 - 2017
Limp mode under heavy acceleration
Old 02-10-2017, 01:08 AM
  #11
tpb857's Avatar
My 14 RS5 did that after running it hard. I had it towed to the dealer the next day. It was a couple of coils.
Old 02-10-2017, 08:41 AM
  #12
SloopJohnB@mac.com's Avatar
Default Do you have a lemon law in Indiana?
Originally Posted by hamiltonua7
The dealership here is completely useless. We only have one here in indianapolis and they had it for an entire month. At first they said hpfp so those were replaced. Then they said o2 sensor but did nothing about it because the following week they said it's the cats. Then the following week they said it's the alternator. And then I finally said screw it and picked the car up when they called me and told me my motor mounts were throwing the fuel codes......
You might try returning the car and/or suing. Or make them give you a good loaner of the same caliber as your car.
Old 02-10-2017, 08:43 AM
  #13
Default would need the codes.
New symptom. Driving home from work at a steady 50mph and noticed it started to sound a little odd. So I gave it a little gas and sure enough it was misfiring and the check engine light started flashing and the epc light came on
If you don't have the ability to read the codes you should probably get it. RossTech makes a good one.
Old 02-10-2017, 09:03 AM
  #14
hamiltonua7's Avatar
i ordered a ross tech cable this week it just hasn't come yet lol. but yesterday it wouldn't even start so I tested the low pressure pump and its dead. just picked one up from the dealer. so in the future if anyone has this issue it could very well be the low pressure pump not providing enough fuel from being weak.
Old 02-11-2017, 05:09 AM
  #15
J. Patterson's Avatar
Good deal. Basic stuff. Frustrating that YOU had to go through all this and dealer didn't find it. Your VAG cable will be a good investment.
Old 02-13-2017, 04:13 AM
  #16
just a quick update guys. I finally got my rosstech cable and was able to scan it. I was getting a fuel pump short circuit. I used a power probe to jump the in tank fuel pump with 12volts directly and it did absolutely nothing. So I went to the dealer and purchased an OEM pump. Put it in, cleared the codes and all is well so far. I will be getting my money back for the other pump that I had JUST replaced at the end of November.
If anyone else runs into these symptoms, check your in tank fuel pump under the rear seat!!
Thank you all for your assistance and suggestions!
Old 02-15-2017, 09:47 AM
  #17
maeghyn's Avatar
Carbon build up??
Old 02-20-2017, 05:42 PM
  #18
Grisho's Avatar
As mentioned on your other thread:
Great to hear that you got this awesome car, not so about the codes though. Here is what could be helpful to check to narrow down the problem:
16471/P0087/000135 - Ross-Tech Wiki
18725/P2293/008851 - Ross-Tech Wiki
Let me know how you get on or anything else you need help with. In any case checking it all with VCDS or similar and posting here is a great way to get help or feel free to contact me directly.
Old 02-21-2017, 06:19 AM
  #19
Default I'm assuming the new fuel pump fixed the issue?
Old 02-21-2017, 06:19 PM
  #20
It fixed the no start issue. I'm still fighting the initial limp mode issue. Is there another fuel filter besides the one attached to the in tank pump?
bigtimer24
10-24-2018 09:02 AM
hamiltonua7
02-14-2017 10:33 PM
Mike_k
06-20-2014 01:44 PM
nasamike
A4 (B7 Platform) Discussion
11-04-2011 09:08 AM
Reggie
RS4 (B7 Platform) Discussion
06-10-2010 09:25 AM
Quick Reply: Limp mode under heavy acceleration
