THE 402 MOD: Audi allroad suspension adjustment how-to
#51
ya, leave the switch alone. the cherry button is like a torque up sport mode in lower gear and it will raise your suspension from 1 to 4 instant in the level control button.
the recode is defintaly spring stiffness, or rate...
#53
Hi guys
is this tool still work good?
my audi is a6 2002 allroad !
and do i have to purchase the software or not ?
because i see this link ~> http://thepiratebay.se/torrent/3512242
and i download it, its work !! ^_^
#54
Hi guys
There's not need to download software "illegally" if it's already free. lol
http://www.ross-tech.com/vcds/download/
Just pick which Ross-Tech VagCom cable you have and download it.
#55
I didn't understand that in total.
lol ok
i don't have any cables but I'll order this cable
http://www.ebay.com/itm/USB-OBD-II-2...item4847293887
Thanks bro
#56
Follow this and see if you can find a seller on the forums.
http://www.ross-tech.com/vag-com/car...ons/100a6.html
#57
I don't want to sound mean, but that won't give you the functionality you probably will need for an allroad.
its like to expensive ~> Price: $249.00 <~
HEX-USB+CAN (USB)
http://store.ross-tech.com/shop/VCKII.html
#58
I found this good price
http://www.ebay.com/itm/VAG-K-CAN-Co...d3bb5f&vxp=mtr
List of vehicles covered from function odometer change via OBDII:
Audi Q7 (CAN)
Audi A2 (K)
Audi A3 (CAN) up to 2007 !!!
Audi A3 VDO/M73 up to 2003 (K)
Audi A4 VDO/M73 (K)
Audi A4 BOSCH - RB4 clusters (CRYPTO eeproms R/W by OBDII)
Audi A6 VDO (K)
Audi A6 (CAN)
Audi Allroud (K) up to 2004
Audi A8 (K) VDO93xx
Audi A8 (CAN) up to 2007 !!!
Audi TT (K)
Audi Q7 (CAN)
Audi A2 (K)
Audi A4 VDO/M73 (K)
Audi A6 VDO (K)
Audi A6 (CAN)
Audi A8 (K) VDO93xx
Audi TT (K)
#59
"17mm in the front and 13mm in the rear will make your car noticeably lower, and you probably shouldn't go any lower. As for height, 20mm was accepted by the vehicle, however, no driving was done at this level, so please excercise caution and common sense. And remember the disclaimer above!!!"
So does this mean we can only lower it less than an inch?
Id like to eliminate the wheel gap (on Level one) and thats it...but thats a couple inches.
#60
402 Mod - limits?
I have mine dropped one of my Allroads quite a bit, I'd say an inch.
I have the stiffer Arnott Gen II in the with worn stock shocks, and new Arnott Bilstein shocks with stock air bags in the rear. THIS combination with 25mm drop results in a bouncy ride in level one (no surprise!). Particularly the front is totally underdampened.
Unfortunately, Arnott has NOT responded to my request to buy their Bistein/Arnott, they send it directly to Bilstein for revalving, Bilstein sends it to me. Until I found a practical way, I will live with the bounce in level 1, use level 2 for normal driving.
The other Allroads sits a tad bit higher, maybe 20mm. Stock bags and shocks. Rides ok in level 1.
Note: I have long abandoned using the '402mm' measurement, since finding the 'center' of the wheel is impractical. Instead, I have followed the suggestion from a poster and measure from the rim edge to the bottom of the fender. I forgot the number that corresponds to 402mm on stock 17" wheels, but I thing it was like 178mm or so.
Lets try the math:
402-17/2*25.4=186mm
Need to check again.
