Audi allroad gearbox issue?
Hi all this is my first post I'm just looking for some help. Basically I have a 2005 audi a6 allroad 2.5tdi
It's having some strange issues with the gearbox so far I have changed the oil and that made no difference I'm thinking it's an ecu issue but hopefully someone will advise.
The car changes up and down gears at the wrong times as in you can go from park to D or manual and it will be in any gear it chooses.
You can be driving along as a constant speed an it will just change to 5th you put your foot down it won't change back down some times putting your foot down it dosent even react at all as in it seems like your tip toeing.
You could be driving along in D then the dash will change as if it's in manual mode same with S.
Various faults showing in the ecu different everytime
2nd 3rd 4th or 5th gear ratio incorrect everytime it jumps into limp mode it's a different gear at fault. You also get excessive slipping but it only slips in limp mode.
Some days I can drive fine for 10 miles other times its every minute or two it jump into limp mode. It seems like the car dosent know the engine load.
Anyway any help really appreciated Adam
Using a snap on scanner atm but when I get back to work I'll be using vagcom. Snap on codes are different everytime there's always 2 codes. One code is always excessive clutch slippage 17195 p0811. The other code is always different which is why I think it's an ecu issue so far I've had
Transmission range sensor f125 implausible signal 17090 p0706
Gear ratio incorrect each time it's a different gear
When I get vagcom I will post real codes as I know these generic scanners are pants
If I drive the car under 50mph it's completely fine most of the time. Thanks for your reply
Check out this thread:
HELP! transmission is in limp mode
I found most of the Google results coming back to a bad valve body.
Is the passenger floor wet?
Thanks again for your reply 😊 I haven't checked the passenger floor but the drivers side floor is dry mines a RHD I have checked the tcm to see if it was damp but all is dry. Also just to mention I have 2 fault codes in the abs one for brake switch implausible signal but I have replaced this I will have to replace again to see if that cures it and the other one is brake pressure sensor faulty I think this is the abs pump itself. Still waiting to get back to work so I can use vagcom. Adam
Saturday,07,January,2017,07:18:53:22113
VCDS Version: Release 16.8.4 (x64) Running on Windows 10 x64
Ross-Tech: Home
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Control Module Part Number: 4Z7 907 389 A
Component and/or Version: ABS/ESP allrad D66
Software Coding: 06457
Work Shop Code: WSC 02334
VCID: 4A9D5CE876E9681257-515A
2 Faults Found:
00526 - Brake Light Switch (F)
27-10 - Implausible Signal - Intermittent
01119 - Gear Recognition Signal
35-10 - - - Intermittent
Saturday,07,January,2017,16:35:30:22113
Ross-Tech: Home
Address 02: Auto Trans Labels: 01V-927-156.lbl
Control Module Part Number: 4Z7 927 156 N
Component and/or Version: AG5 01V 2.5lTDI RdW 2222
Software Coding: 00001
Work Shop Code: WSC 00000
VCID: 51AF4B849BBF5BCA16-515A
2 Faults Found:
17118 - Gear 4
P0734 - 35-00 - Incorrect Ratio
17195 - Excessive Clutch Slippage
P0811 - 35-00 -
Ross-Tech: Home
2 Faults Found:
17118 - Gear 4
P0811 - 35-00 -
Saturday,07,January,2017,07:32:50:22113
Ross-Tech: Home
3 Faults Found:
17116 - Gear 2
P0732 - 35-10 - Incorrect Ratio - Intermittent
17118 - Gear 4
P0811 - 35-00 -
Saturday,07,January,2017,07:35:45:22113
Ross-Tech: Home
2 Faults Found:
17118 - Gear 4
P0811 - 35-00 -
Saturday,07,January,2017,07:50:49:22113
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 16.8.4.2 (x64)
Data version: 20161129 DS267.0
Ross-Tech: Home
VIN: WAUZZZ4B65N024646 License Plate:
Chassis Type: 4B (4B - Audi A6/S6/RS6/allroad C5 (1998 > 2005))
Scan: 01 02 03 06 08 15 16 17 18 22 34 35 36 37 45 55 56 57 65 67
75 76 77
07725901870
Address 01: Engine Labels: 059-907-401-AKE.clb
Part No: 8E0 907 401 J
Component: 2.5l/4VTEDC G000AG 0006
Coding: 06006
Shop #: WSC 01194
VCID: 2C513A70DC5D562245-4B00
WAUZZZ4B65N024646 AUZ7Z0D2694573
No fault code found.
Readiness: 0 0 X X X
Part No: 4Z7 927 156 N
Component: AG5 01V 2.5lTDI RdW 2222
Coding: 00001
Shop #: WSC 00000
Part No: 4Z7 907 389 A
Component: ABS/ESP allrad D66
Coding: 06457
Shop #: WSC 02334
3 Faults Found:
01203 - Electrical Connection between ABS and Instrument Cluster
03-10 - No Signal - Intermittent
Address 08: Auto HVAC Labels: 4B0-820-043-MY2.lbl
Part No: 4B0 820 043 AR
Component: A6-Klimavollautomat 0208
Coding: 00104
Shop #: WSC 02335
VCID: 6ADDFC681629881277-2580
Address 15: Airbags Labels: 4B0-959-655-AI84.lbl
Part No: 4Z7 959 655 M
Component: Airbag 8.4EP 1000
Coding: 0001106
Shop #: WSC 02334 785 00200
VCID: 59BFB3A4934F138AEE-515A
Address 16: Steering wheel Labels: 4B0-907-487.lbl
Part No: 4B0 907 487 H
Component: Lenkradelektronik D01
Coding: 01012
Shop #: WSC 02334
VCID: 316F2B04FB7F3BCA76-513C
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 981 J
Component: KOMBI+WEGFAHRS. VDO D17
Coding: 04460
Shop #: WSC 11264
VCID: 2D573774E7475F2A52-515A
1 Fault Found:
01302 - Control Module for Telematic (J499)
49-00 - No Communications
Address 34: Level Control Labels: 4Z7-907-553.lbl
Part No: 4Z7 907 553 F
Component: - 2C1A1 D060
Coding: 25500
Shop #: WSC 02334
VCID: 489966E068E59A0241-515A
2 Faults Found:
01437 - Control Position not Learned
35-00 - -
01770 - Temperature Sensor for Level Control Pump/Compressor (G290)
30-10 - Open or Short to Plus - Intermittent
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Part No: 4B0 962 258 N
Component: Zentralverrieg.,DWA D38
Coding: 06859
Shop #: WSC 02335
VCID: 34612210046D0EE21D-4F1E
8 Faults Found:
01366 - Opened Due to Crash Signal
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01572 - Alarm triggered by Door Contact Switch; Passenger Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01574 - Alarm triggered by Door Contact Switch; Rear Right
35-00 - -
01573 - Alarm triggered by Door Contact Switch; Rear Left
35-00 - -
Address 37: Navigation Labels: 8E0-035-192-RNSE.clb
Part No SW: 4B0 035 192 P HW: 4B0 035 192 P
Component: RNS-E HIGH EU H52 0650
Revision: 07S Serial number: AUZBZ7D0500188
Coding: 0502717
Shop #: WSC 00001 124 00243
VCID: 2A5D3C6886A94812B7-5196
1 Fault Found:
02261 - Data Medium
014 - Defective
Freeze Frame:
Fault Status: 01111110
Fault Priority: 5
Fault Frequency: 90
Reset counter: 186
Time Indication: 0
Date: 2016.12.19
Time: 18:38:41
Freeze Frame:
Mileage: 655350 km
Count: 2112
Clock: 17:50
Address 45: Inter. Monitor Labels: 4B0-951-178.lbl
Part No: 4B0 951 178 A
Component: Innenraumueberw. D04
Coding: 00102
Shop #: WSC 02334
VCID: 2645C858C2B16C7293-515A
Address 55: Headlight Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00030
Shop #: WSC 00081
VCID: 0401B2D0144D7E62ED-4B32
Address 56: Radio Labels: 8E0-035-192-RNSE.clb
Coding: 0502717
1 Fault Found:
02261 - Data Medium
014 - Defective
Freeze Frame:
Fault Priority: 5
Fault Frequency: 90
Reset counter: 186
Time Indication: 0
Date: 2016.12.19
Time: 18:38:41
Freeze Frame:
Mileage: 655350 km
Count: 2112
Clock: 17:50
Address 76: Park Assist Labels: 8E0-919-283-8E2.lbl
Part No: 8E0 919 283
Component: Parkingsyst. A6 RDW D09
Coding: 11186
Shop #: WSC 02334
VCID: 6DD7F77427C79F2A12-515A
2 Faults Found:
01627 - Sensor for Parking-Aid; Front Mid-Right (G253)
31-00 - Open or Short to Ground
01629 - Sensor for Parking-Aid; Front Left (G255)
31-10 - Open or Short to Ground - Intermittent
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 AA HW: 8P0 862 335 S
Component: FSE_256x BT H38 0600
Revision: 00000000 Serial number: 00000005133080
Coding: 0010822
VCID: 75E7DF141F9757EAEA-515A
End-------------------------(Elapsed Time: 05:02)--------------------------
vagcom scan
Ross-Tech: Home
2 Faults Found:
Ross-Tech: Home
2 Faults Found:
17118 - Gear 4
P0811 - 35-00 -
Ross-Tech: Home
2 Faults Found:
17118 - Gear 4
P0811 - 35-00 -
Ross-Tech: Home
3 Faults Found:
17116 - Gear 2
17118 - Gear 4
P0811 - 35-00 -
Ross-Tech: Home
2 Faults Found:
17118 - Gear 4
P0811 - 35-00 -
Ross-Tech: Home
75 76 77
07725901870
Coding: 06006
Shop #: WSC 01194
Coding: 00001
Shop #: WSC 00000
Coding: 06457
Shop #: WSC 02334
3 Faults Found:
Coding: 00104
Shop #: WSC 02335
Coding: 0001106
Coding: 01012
Shop #: WSC 02334
Coding: 04460
Shop #: WSC 11264
1 Fault Found:
Coding: 25500
Shop #: WSC 02334
2 Faults Found:
35-00 - -
Coding: 06859
Shop #: WSC 02335
8 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
Coding: 0502717
1 Fault Found:
02261 - Data Medium
014 - Defective
Freeze Frame:
Fault Priority: 5
Fault Frequency: 90
Reset counter: 186
Time Indication: 0
Date: 2016.12.19
Time: 18:38:41
Freeze Frame:
Mileage: 655350 km
Count: 2112
Clock: 17:50
Coding: 00102
Shop #: WSC 02334
Coding: 00030
Shop #: WSC 00081
Coding: 0502717
1 Fault Found:
02261 - Data Medium
014 - Defective
Freeze Frame:
Fault Priority: 5
Fault Frequency: 90
Reset counter: 186
Time Indication: 0
Date: 2016.12.19
Time: 18:38:41
Freeze Frame:
Mileage: 655350 km
Count: 2112
Clock: 17:50
Coding: 11186
Shop #: WSC 02334
2 Faults Found:
Coding: 0010822
vagcom scan
How many miles are on the tranny?
I think it would be worth checking the connections at the TCU. I believe your TCU box has a better seal, but I would check for corrosion anyway.
If that checks out, it sounds like an internal issue. Torque convertor, clutches, valve body, solenoid, etc.
Thanks for the reply as far as I know it's the origional box 190k. I have checked the tcu in the drivers footwell seems ok should I open it up and check inside? Also where's the main connection from the tcu to gearbox is it near the drive shaft?
Adam
Adam
