Battery drain issue update (additional help needed)
Old 02-11-2009, 07:54 PM
New Member
deba0016's Avatar
Default Battery drain issue update (additional help needed)
So my recently acquired 2001 tip allroad has a battery drain that prevents it from starting after 24-48 hours.
I pulled every fuse in the car with an ammeter in between the battery and ground. Battery had a fresh charge. I was getting a draw from fuse 17 (Navigation) of .25 amps. I also got a drain from fuse 37 (Radio/Telephone) of .24 amps.
With the door open and all fuses in place: 1.75 amps total
With door closed and all fuses in place: .83 amps
With door closed and fuse 17 and 34 pulled: .20amps
With these 2 fuses pulled I have no radio (duh) and no ability to adjust traction control or the air suspension (warning light on dash also).
I had a local scan the car with a VAG-COM and will post the link in my next post.
What is the normal drain for this car?
What is the best source for a wiring diagram?
What would you suggest I try next?
The driver's side memory seat does not work and either does the heated seat. Related? The VAG-COM report mentions this but my fuse pulling test would not indicate this as a problem.
Thanks!
Old 02-11-2009, 07:55 PM
New Member
deba0016's Avatar
Default Re: complete VAG-COM report
Chassis Type: 4B - Audi A6 C5
Scan: 01 02 03 06 08 15 16 17 18 34 35 36 37 45 55 56 57 65 67 75
76 77
Address 01: Engine Labels: 078-907-551-AZA.lbl
Part No: 4Z7 907 551 M
Component: 2.7l V6/5VT G 4000
Coding: 06752
Shop #: WSC 20213
WAUYP64B01N083024 AUZ7Z0Y1646067
1 Fault Found:
17866 - Exhaust Gas Temp Sensor 2 (G236): Short to Ground
P1458 - 35-10 - - - Intermittent
Readiness: 0110 1101
Address 06: Seat Mem. Pass Labels: None
Part No: 4B0 959 760 C
Component: Sitzmemory R1 BF 0102
Coding: 00003
Shop #: WSC 00000
2 Faults Found:
00668 - Supply Voltage Terminal 30
07-00 - Signal too Low
06-00 - Signal too High
Address 34: Level Control Labels: 4Z7-907-553.lbl
Part No: 4Z7 907 553 B
Component: - 2C1A1 X031
Coding: 25500
Shop #: WSC 09999
1 Fault Found:
01400 - Suspension Level Control
53-10 - Supply Voltage Too Low - Intermittent
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Part No: 4B0 962 258 J
Component: Central Lock/Alarm D33
Coding: 15885
Shop #: WSC 02325
8 Faults Found:
01572 - Alarm triggered by Door Contact Switch; Passenger Side
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
07-10 - Signal too Low - Intermittent
00991 - Interior Lights
28-10 - Short to Plus - Intermittent
00955 - Key 1
09-10 - Adaptation Limit Surpassed - Intermittent
00956 - Key 2
01561 - Left Rear Door
59-00 - Can't Unlock
01562 - Right Rear Door
59-10 - Can't Unlock - Intermittent
Address 36: Seat Mem. Drvr Labels: None
Part No: 4B0 959 760 B
Component: Sitzmemory R1 F 0101
Coding: 00001
Shop #: WSC 00000
2 Faults Found:
06-10 - Signal too High - Intermittent
Address 45: Inter. Monitor Labels: None
Part No: 4B0 951 178 A
Component: Innenraumueberw. D04
Coding: 00102
Shop #: WSC 02325
2 Faults Found:
01349 - Alarm via Theft Warning System; Front
35-00 - -
01462 - Anti-theft alarm ultra sonic Sensor (G209)
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D05
Coding: 00030
Shop #: WSC 02325
1 Fault Found:
00532 - Supply Voltage B+
End ---------------------------------------------------------------------
Old 02-11-2009, 08:16 PM
Member
Ex-PzKW Cdr's Avatar
Did you get the battery load tested??
Old 02-11-2009, 08:46 PM
New Member
deba0016's Avatar
Re: Battery is newish, unrelated
Old 02-11-2009, 09:03 PM
Senior Member
Rally_nutcase_1982's Avatar
Default Makes no difference, you should load test this thing, it's a step of the elimination process...
every new part can always have a manufacturing fault, listen to Ex-PZKW, he knows this stuff.
Old 02-12-2009, 12:41 AM
samm's Avatar
Default Re: VAG-COM report
Did you VAG the car after you pulled fuses? If so then there is no way of telling which codes are a result of pulling fuses and which are real faults. There seem to be way too many faults related to voltage so I suspect you VAG after pulling fuses. If this is the case, clear the codes then re-scan.
Old 02-12-2009, 02:51 AM
paulroad's Avatar
Default being this is the first time you scanned you car... clear all the codes.
Then after an hour or so of driving, scan it again and see the 'fresh codes'.
What you showed on the post is a history of prev. faults.
Old 02-12-2009, 04:23 AM
New Member
deba0016's Avatar
Default Re: Battery was from 8/08 and the previous owner said the problem was there with the previous batter
I will have the battery load tested but it doesn't seem to answer the large draw from two of my fuses.
Old 02-12-2009, 04:26 AM
New Member
deba0016's Avatar
Default Re: I should have clarified.
The report I posted was the second report done. First we scanned it, then cleared it, then I drove around the block and rescanned it. All of this was done before any fuses had been pulled.
Old 02-12-2009, 04:27 AM
New Member
deba0016's Avatar
Re: This was done before pulling any fuses
Quick Reply: Battery drain issue update (additional help needed)
