Really don't know
Really don't know
Hello guys,
I'm new one here, so if I write something as it should not be please let me know
So my problem seams to appear recently to a lot of AR users, but still digging true topics didn't found the answer.
Yesterday driving from job after turning right the side flashing signal from flashing went to fixed, but after few minutes fixed light again turned back to normal. I though its just a kind of silly problem, but day after as i woke up i saw that my car in parking place stays with fixed emergency lights ( all of them ). I tried to change the relay, but it didn't help, also i disconnected my battery and tried the bulbs and fuses. Guys I really don't know what to do here since every thing i possible could do i think i have done..
Some suggestions and maybe some of you could handle this kind of problem..
Hmmmm, since you've replaced the relay it may be something to do with the actual turn signal stock. Perhaps the switch inside there is sticking causing the weird lighting. Just a guess because I really don't know.
Welcome to the forums. I can't help you with your technical question...but I can make these two suggestions:
Use a good descriptive title for your posts. "Really don't know" isn't helpful and won't get a lot of people to read your actual post.
Second, provide good information about your car -- year, model, engine, mileage, how long you've owned it, etc. This will help us to better respond to your question with useful information...
When you say 'relay', are you talking about the hazard light switch mechanism?
Mine had similar symptoms, the hazard light switch is also the indicator 'flasher'.
Sometimes it would blink once then stay on, other times it would start to blink the go off.
Part number 4B0941509KB98 (for my 2004).
To replace, pry the trim off from the bottom edge (use something flat so you don't damage the soft feel radio trim, old credit card or similar), the hazard switch has a clip on each side, pull forward, pull forward, 1 large connector on the back.
Where did you buy the new hazard switch? It could still be defective, especially if nothing changed after replacing it. Does it say OEM China on it?
Otherwise, turn signal stalk is bad, like it was suggested before.
SiV6Qcoupe
Audi 100 / A6 (C4 Platform)
12-01-2003 02:15 PM
