Service! Light
Service! Light
The Service light (2003 AR) has come on and now it drives me crazy! It only lights up when i first start up. I am sure it is the light for oil -
Anyone know of to reset it or turn it off?
I also have a check engine light
Unsure of the code but the read out was:
Insufficient airflow (both sides) Unsure what it might be. Everything is running top-notch gas mileage, Power, Turbos,
Thanks for the help!!
Banned
to reset the service indicator, with the key in the off position, hold the odo reset button.
while holding it down turn the key to the ACC position, and that should reset the service dingy.
the insufficient flow code is telling you either the SAI pump is toast or the combi valves are malfunctioning
