Suspension question.. Light is solid on dash.
I recently purchased an 2001 allroad with a bad r/f air bag.
Replaced both left & right front bags. Car is still down in the weeds!
So my question is, does the suspension comp go into a default mode when it senses a bad bag/ air leak ? And what would be my next step in correction this problem? Thank you j kopo
You will need to hook up VAG COM (diagnostic software) to read what is going on with the suspension computer.
The suspension computer will time out if a number of things happen. Things like if the compressor gets too hot, one or more of the level sensors is way out of range, time limit on compressor run time. Things like that.
What you need to do is lift up both front sides to where the car would be at level 2. Turn on the car; if the airsprings are seated properly and your compressor is not shot, the springs should inflate... Try that and report back...
I tried lifting the front of the car today and still nothing.
Had a friend put a scanner on it and it punched out codes
01769!r ft level control, 00776 self leveling sensor fl-g78 & control mad for vertical headlamp aim -j431
jack mood
When you lift the the car or\and when you repair the height System component the car must be in "JACK MOOD" and Main switch is turned off.
Is recommended to check the air bag \ shock absorber for Air leaks Before you connect it in the car.
for the test You can switch between the right front height sensor and the left front sensor they are the same
