Suspension Warning Lights Again
I have the dreaded yellow warning lights on my 2001 Audi allroad – air suspension light, esp, abs. Changed the brake light switch three times. Turn engine off – hook up computer, turn ignition on - when I scan I get the following codes:
Address 01: Engine Labels: 078-907-551-AZA.LBL
Controller: 4Z7 907 551 M
Component: 2.7l V6/5VT G 0001
Coding: 06752
Shop #: WSC 02301
VCID: 4DED8A3F94DF
WAUYP64B81N133619 AUZ7Z0A1784649
2 Faults Found:
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 35-10 - - - Intermittent
17539 - Oxygen (Lambda) Sensor; B2 S1: Internal Resistance too High
P1131 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8D0-907-389.LBL
Controller: 4Z7 907 389
Component: ABS/ESP allrad D57
Coding: 06397
Shop #: WSC 02325
VCID: 09657E2F2037
1 Fault Found:
00778 - Steering Angle Sensor (G85)
37-10 - Faulty - Intermittent
Address 34: Level Control Labels: 4Z7-907-553.LBL
Controller: 4Z7 907 553 BF
Component: - 2C1A1 X031
Coding: 25500
Shop #: WSC 09999
VCID: 8A67C123A531
1 Fault Found:
01316 - ABS Control Module
79-10 - Please Check Fault Codes - Intermittent
When the lights come on and I keep the engine running while scanning I get these codes:
Coding: 06397
Shop #: WSC 02325
VCID: 09657E2F2037
1 Fault Found:
37-00 - Faulty
Coding: 25500
Shop #: WSC 09999
VCID: 8A67C123A531
1 Fault Found:
79-00 - Please Check Fault Codes
I guess the scans are pointing toward steering angle sensor and / or ABS. Any help in interpreting these scans would be appreciated.
Eckhard
Coding: 06752
Shop #: WSC 02301
VCID: 4DED8A3F94DF
2 Faults Found:
Coding: 06397
Shop #: WSC 02325
VCID: 09657E2F2037
1 Fault Found:
Coding: 25500
Shop #: WSC 09999
VCID: 8A67C123A531
1 Fault Found:
Coding: 06397
Shop #: WSC 02325
VCID: 09657E2F2037
1 Fault Found:
37-00 - Faulty
Coding: 25500
Shop #: WSC 09999
VCID: 8A67C123A531
1 Fault Found:
Eckhard
After doing more research I found out it was the clock spring behind the steering wheel. I found a used one for $80 and put it in - no more problems. The steering wheel is easy to remove, just make sure the battery is disconnected.
Hope this helps
Eckhard
Hope this helps
Eckhard
Do you have the part number for the spring?
Thanks
Clock Spring
I don't have the part # but make sure you get the one with stability program - at least that is what my allroad needed. I got mine from Wolf Auto Parts - Audi and Volkswagen Parts
they also have an ebay store
Audi Parts, VW parts items in Used Audi Parts store on eBay!
they dismantle Audis and VW's - I have bought a few parts from them and I have no complaints. You can also do an ebay search - that's how I found these guys.
Good luck. Make sure you disconnect the battery before you take the airbag out.
Ian Taylor
New Member Welcome Area
11-22-2017 11:39 PM
Avant Redux
Audi allroad
09-27-2005 12:46 PM
