Suspension Warning Lights Again
Old 09-24-2012, 05:24 PM
VW_Fahrer's Avatar
Default Suspension Warning Lights Again
I have the dreaded yellow warning lights on my 2001 Audi allroad – air suspension light, esp, abs. Changed the brake light switch three times. Turn engine off – hook up computer, turn ignition on - when I scan I get the following codes:
Address 01: Engine Labels: 078-907-551-AZA.LBL
Controller: 4Z7 907 551 M
Component: 2.7l V6/5VT G 0001
Coding: 06752
Shop #: WSC 02301
VCID: 4DED8A3F94DF
WAUYP64B81N133619 AUZ7Z0A1784649
2 Faults Found:
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 35-10 - - - Intermittent
17539 - Oxygen (Lambda) Sensor; B2 S1: Internal Resistance too High
P1131 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8D0-907-389.LBL
Controller: 4Z7 907 389
Component: ABS/ESP allrad D57
Coding: 06397
Shop #: WSC 02325
VCID: 09657E2F2037
1 Fault Found:
00778 - Steering Angle Sensor (G85)
37-10 - Faulty - Intermittent
Address 34: Level Control Labels: 4Z7-907-553.LBL
Controller: 4Z7 907 553 BF
Component: - 2C1A1 X031
Coding: 25500
Shop #: WSC 09999
VCID: 8A67C123A531
1 Fault Found:
01316 - ABS Control Module
79-10 - Please Check Fault Codes - Intermittent
When the lights come on and I keep the engine running while scanning I get these codes:
Coding: 06397
Shop #: WSC 02325
VCID: 09657E2F2037
1 Fault Found:
37-00 - Faulty
Coding: 25500
Shop #: WSC 09999
VCID: 8A67C123A531
1 Fault Found:
79-00 - Please Check Fault Codes
I guess the scans are pointing toward steering angle sensor and / or ABS. Any help in interpreting these scans would be appreciated.
Eckhard
Old 04-28-2016, 04:08 AM
BjarkeDenmark's Avatar
Hi
I assume that you found the issue.
What did you find out. Have the same fault right now
Cheers
Old 04-29-2016, 07:57 AM
Banned
PaperToast's Avatar
looks like the abs module could be causing some of the codes
it could have failed, or there is a bad connection along the wiring
Old 05-02-2016, 05:51 AM
VW_Fahrer's Avatar
After doing more research I found out it was the clock spring behind the steering wheel. I found a used one for $80 and put it in - no more problems. The steering wheel is easy to remove, just make sure the battery is disconnected.
Hope this helps
Eckhard
Old 06-29-2016, 09:27 AM
kiertzner's Avatar
Hope this helps
Eckhard
Hi.
Do you have the part number for the spring?
Thanks
Old 06-30-2016, 03:40 AM
MrKid's Avatar
2001 AUDI S4 2.7L V6 Turbocharged Air Bag Clockspring | RockAuto
Old 07-04-2016, 07:41 PM
VW_Fahrer's Avatar
Default Clock Spring
I don't have the part # but make sure you get the one with stability program - at least that is what my allroad needed. I got mine from Wolf Auto Parts - Audi and Volkswagen Parts
they also have an ebay store
Audi Parts, VW parts items in Used Audi Parts store on eBay!
they dismantle Audis and VW's - I have bought a few parts from them and I have no complaints. You can also do an ebay search - that's how I found these guys.
Good luck. Make sure you disconnect the battery before you take the airbag out.
Ian Taylor
New Member Welcome Area
11-22-2017 11:39 PM
terry425
06-30-2008 01:05 PM
pjohns3
Audi allroad
09-18-2006 05:32 PM
schnellmb
10-25-2005 03:26 PM
Quick Reply: Suspension Warning Lights Again
