symphony ii / Tlematics (Onstar) ings down k2???
Symphony ii radio / Telematics (Onstar) shorts k2???
I have the water leak, passenger flood issue. The car runs but I have to replace the standard ESP and Auto Trans modules - which are removed. At first K1 and K2 were shorted but the removal of the two modules freed K1 from shorting. When starting the engine after the removal of the ESP and Trans modules, the radio panel showed "PHONE" and some garbled ring sound came from the speakers connected in the OnStar circuit. Turned off the ignition but the panel and ringing do not reappear. VAG says K2 shorted. Also Radio and Telematics are interconnected on the K1 and K2 busses for telematics function. So, I can't rule out either or both.
I can see the Telematics module and the 3 mounting nuts but cannot see the power and antenna connectors. Also every thing is tight there. The question is if I remove the Module from the mount does anyone know if there is enough play in the connecting cables to allow them to be disconnected? (Pictures and discussions are sparse to nil on the web.)
The radio is coming out as soon as my removal tools arrive.
Thanks.
Thanks.
Thanks.
Thanks.
Let me know if you make progress on this and I'll do the same... my car is in pieces right now, with the carpet hanging from the rafters, still dripping!
Do you have the vcds? If your k1 and k2 lines are not shorted then you can get module status from vcds. Does your car start?
We may not have the same problem but do have similar circumstances. My vcds is showing that the K2 line is shorted. Because of this I cannot get any module reading but all seems to work after replacing the trans module. No dash lights, etc. Car runs great but k2 shorted (started this venture with both shorted). Up front, Radio, telematics, heat & air conditioning, and central locks modules are on k2.
Since the post I've removed the radio. Not a solution. Heat & Air not the problem. Still haven't tried to get to telematics - no guts yet.
