Any idea what type of Bilstein Shock this is?
The rear Bilstein shock numbers on my rear 95.5 with H&R springs are:
3408B46 2065H0
Any one knows what these numbers mean? Is there a way I can tell if it is HD or sport Bilsteins?
Thanks
3408B46 2065H0
Thanks
There is/was a Bilstein application guide that said/says Old Part number = F4-B46-2065-H0 is now New Part Number = 24-020657
The when you search the pdf (with Ctrl F) for 24-020657, it shows up in the C4 100 quattro and C4 A6/S6 quattro listings as the rear B6 HD shock. It is a Heavy Duty, not a B8 Sport. With H&Rs, because they lower the car so much, B8s would be more appropriate than B6s.
As far as I can tell, they are rear B6 = HD shocks
Will it be firmer or softer than it is now?
Will it lift the car a little bit or lower it?
This is what it looks like now.. It appears the rear is a little higher than the front is that normal?
Thanks for the reply... That's exactly what I was thinking based on my reviews in the forum. If my car is H&R then Bilstein Sport should be considered, but when I checked the shocks they appear to be HDs. What should I expect with the Sport shocks? Will it be firmer or softer than it is now? Will it lift the car a little bit or lower it? This is what it looks like now.. It appears the rear is a little higher than the front is that normal?
Sometimes springs sag. Not sure what your issue would be.
Luxus Panzer
08-09-2007 06:05 PM
Brdman*
03-28-2003 07:22 AM
A4agarwal
11-13-2000 08:06 PM
