Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
Need Diagnostic Help
Old 07-14-2006, 03:08 PM
SchwarzS6's Avatar
Default Need Diagnostic Help
My car started running rough today. I am afraid I know why but I would like some more experienced opinions.
I drove about 10 miles on the highway, pulled off and into a parking lot. When I parked the car the idle was rough. An hour later I came out and started the car, again the idle was rough. When I drove home on the highway the power was really poor, almost no torque at less than 3,000rpm. If I stepped on the gas at 60mph in 5th (2,600 rpm) the engine was very rough.
When I got home and parked the car I left it running. There was a very strong sulfer odor. I put my hand behind the exhaust pipe and the exhaust pulses were definitely. The engine was not shaking when I looked at or felt it.
What do you think? Where should I look for problems? Will a VAG analysis tell me anything?
Old 07-14-2006, 03:15 PM
UrS4boy's Avatar
Default <Somebody just shoot me> Please see the URL inside. Sounds like it could be...
as simple as you have loose sparkplugs. Go through the procedure in the URL link. You WILL find the problem.
Again, doesn't anybody use "Search Forums" before asking their question?<ul><li><a href="https://forums.audiworld.com/s4s6/msgs/115408.phtml">https://forums.audiworld.com/s4s6/msgs/115408.phtml</a</li></ul>
Old 07-14-2006, 03:28 PM
Guest
VR_Life's Avatar
Default Yes. This forum is provided here deliberately to annoy you . . .
Carefull what you wish for :-P
Old 07-14-2006, 03:34 PM
UrS4boy's Avatar
Default Exactly.
;&gt
Old 07-14-2006, 04:43 PM
SilberUrS6's Avatar
Default :PoW!:
OK, so don't post help - just give the standard "STFA."
Or, "Your engine is dead. Sell your car to me for $1000."
Old 07-14-2006, 05:09 PM
UrS4boy's Avatar
Thanks. (I would say "STF'nA" but nobody knows how to do it)
Old 07-14-2006, 05:25 PM
repeater's Avatar
Default We've been agreeing alot lately...
Who performed the exorcism?
Old 07-14-2006, 05:31 PM
SchwarzS6's Avatar
OK Next time I'll STFA first, Geez, its Friday night, chill out
Old 07-14-2006, 05:40 PM
SchwarzS6's Avatar
Default Thanks for the link, I do appreciate it
I pulled the plugs and checked them. They do look like they have been in there a while. I will get new ones tomorrow.
Once I got the plugs out I looked into each cylinder with a flashlight. #4 looks wet, the others look dry so I will make the assumption that #4 is probably the bad one. I pulled the wire, the boot looks fine. The resistance checks out to 5kohms just like it should. The plug measures 1.2kohms which I also assume is correct.
According to UrS4boy this would point to the POS since the engine is rough at idle. Fortunately plugs 4 and 5 are on the POS with the extra channel.
I will throw in new plugs and then run through the rest of the diagnostic procedure and see if it still points to #4 and the POS.
Is the POS this part? If so it is a little pricey.
http://www.autohausaz.com/search/productx.aspx?sid=3ho0gtmukztsoa450n2tor55&amp;mak eid=800002@Audi&amp;modelid=1009370@S6%20TURBO&amp ;year=1995&amp;cid=25@Ignition%20Parts&amp;gid=717 2@Ignition%20Control%20Unit/Ignition%20Control%20Module
Old 07-14-2006, 05:48 PM
spiralsmurf's Avatar
that is the price for a new POS. you can do the whole 1.8t conversion for about that price.
Quick Reply: Need Diagnostic Help
