Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
How hard is it to attach a CPS to the bracket? Is is screwed in or what?
Old 07-13-2008, 10:39 AM
Wahhab's Avatar
Old 07-13-2008, 11:17 AM
Fastscirocco's Avatar
It's attached with rivets, easy to swap out.
Old 07-13-2008, 11:37 AM
Wahhab's Avatar
Default you rivet back in I am assuming? I am trying to figure all the parts I need prior to
doing the job because it is my only wheels if you know what I mean. Other wise I am walking to the store in this Texas heat, which is blistering hot.
Zwoobah's Avatar
not rivets, attached with small metal pins that you flare out. they come attached to the CPS
Old 07-13-2008, 11:43 AM
Wahhab's Avatar
Default you are talking about this one correct?
<ul><li><a href="http://www.bbautomacao.com/proddetail.asp?prod=VANE301">http://www.bbautomacao.com/proddetail.asp?prod=VANE301</a</li></ul>
Old 07-13-2008, 12:04 PM
yes, the brass you see is one side of the "rivet" on the other side is the unflared side, easy swap
A hollow metal pin you flare out = rivet in my book! : - )
Old 07-13-2008, 12:14 PM
UrS4boy's Avatar
agree
Old 07-13-2008, 12:55 PM
UrS4boy's Avatar
Default Tell me you've looked in the FAQ and found this:
<ul><li><a href="https://forums.audiworld.com/s4s6/msgs/195614.phtml">https://forums.audiworld.com/s4s6/msgs/195614.phtml</a</li></ul>
Old 07-13-2008, 04:55 PM
Wahhab's Avatar
yes, I did find.
Quick Reply: How hard is it to attach a CPS to the bracket? Is is screwed in or what?
