Sponsored by:
Sponsored by:
Bose audio problem after firmware update
Old 02-25-2017, 01:26 AM
rebelAudi's Avatar
Default Bose audio problem after firmware update
Help!! On January 5, 2017 around 14:30 I updated the firmware (K900) and maps for my A7 with Bose system, trusting this person who apparently professed expert, then instead is nothing but good to flush out the update files!
The Bose system is not working as it should, I have the DVD to test the Dolby system (trying individual cases) and would suggest you download it from eMule, burn it and prove it to you, if you have the Bose! The front center speaker does not work, the sub does not work and the surround speakers are driven with front legs as if we had just a poor stereo sound system. Even the Bluetooth audio and navigation are not reproduced on the entire plant, but only on the front left speaker and the voice is muffled. I think something has been overwritten during the upgrade, in fact, some errors (taken with VAG) have date and time coincident with the upgrade. Does anyone have an A7 with Bose and the ability to send a press of indicted addresses to see the differences? Or you know what parameters via VAG enable the activation of Bose? The workshop Audi does not know to solve and the only solution for them would be to replace all for the modest sum of € 5000
Who can help me?
Thursday,26,January,2017,15:33:21:53046
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
Ross-Tech: Home
VIN: WAUZZZ4G1CN020240 License Plate:
Mileage: 126784km-78779mi Repair Order:
Chassis Type: 4G (4G0)
Scan: 01 02 03 05 06 08 09 10 13 15 16 17 19 22 28 34 36 3B 3C 42
44 46 47 52 53 55 56 5F 62 6C 6D 72 84 85 88 89 8B 8E 8F 90
VIN: WAUZZZ4G1CN020240 Mileage: 126784km-78779miles
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 4G0 907 468 E HW: 4G0 907 468 A
Component: J533--Gateway H08 0213
Revision: -------- Serial number: 00000000183698
Coding: 00CD077D00
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_GatewUDS 001025
ROD: EV_GatewUDS_AU57.rod
VCID: 326D6C0F65E057B1A8B-8067
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0140
Serial number: 00000000005650814121
Voltage stabilizer:
1 Fault Found
6227 - Digital sound System control module
U106A 00 [008] - No Communication
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 2
Reset counter: 84
Mileage: 126261 km
Date: 2017.01.05
Time: 14:37:37
Address 47: Sound System (J525) Labels: None
Part No SW: 4G0 035 223 C HW: 4G0 035 223 A
Component: BOSE-G3-C7 H07 0160
Revision: CJ007000 Serial number: 00000000006717
Coding: 030000
VCID: 1D37AFB3047EF8C9659-8048
5 Faults Found
00876 - Treble Speaker Rear Left (R14)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 4
Fault Frequency: 8
Reset counter: 94
Mileage: 126557 km
Time Indication: 0
Date: 2017.01.19
Time: 16:28:27
02558 - Rear Left Mid-Range/Woofer Loudspeaker (R159)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 8
Reset counter: 94
Mileage: 126557 km
Time Indication: 0
Date: 2017.01.19
Time: 16:28:27
00877 - Treble Speaker Rear Right (R16)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 94
Mileage: 126557 km
Time Indication: 0
Date: 2017.01.19
Time: 16:28:27
02559 - Rear Right Mid-Range/Woofer Loudspeaker (R160)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 94
Mileage: 126557 km
Time Indication: 0
Date: 2017.01.19
Time: 16:28:27
03389 - Data Set Implausible
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 54
Time Indication: 0
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4G1 035 053 J HW: 4G1 035 053
Component: Radio U Basic H41 0133
Revision: AB001007 Serial number: 049FT0BB007104
Coding: 010003010000000001
VCID: 2645805F51283B11343-8073
No fault code found.
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 4G0 035 670 P HW: 4G0 035 670
Component: H-BNT-EU H47 0939
Revision: -------- Serial number: 428F30B7517695
Coding: 090100040003F9EF7D34CB1E00000003080001000000000000
Shop #: WSC 21885 150 999999
VCID: 3069660763EC65A1DEF-8065
Subsystem 1 - Part No: 8R0 060 884 ED
Component: EUR 2017 2402
Subsystem 2 - Part No SW: 4G0 919 605 A HW: 4G0 919 605 A
Component: DU8 C7 SV H42 0021
Subsystem 3 - Part No SW: 4G1 919 610 C HW: 4G1 919 610 A
Component: E380 BDT C7 H08 0204
Subsystem 4 - Part No: 8R0 060 961 B
Component: CD-Database 3371
3 Faults Found
03276 - Please Check Software Version Management
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 44
Mileage: 126261 km
Time Indication: 0
Date: 2017.01.05
Time: 15:35:53
Freeze Frame:
Text: KBD_FC7,KBD,M,0,0,6
03175 - Invalid Data Set
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 44
Mileage: 126261 km
Time Indication: 0
Date: 2017.01.05
Time: 15:29:20
Freeze Frame:
Voltage: 14.60 V
03623 - Invalid Secruity/Release Code
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 44
Mileage: 126261 km
Time Indication: 0
Date: 2017.01.05
Time: 17:46:38
Freeze Frame:
Hex Value: 0x0004
Hex Value: 0x0009
Count: 7
chuckyarla
10-18-2012 03:59 PM
TGABTG
A4 (B7 Platform) Discussion
09-14-2006 05:36 PM
Kugs10
05-10-2001 11:33 AM
S42N8
01-13-2001 04:55 PM
Jack
01-13-2000 02:05 PM
Quick Reply: Bose audio problem after firmware update
