Sponsored by:
Sponsored by:
no rear view camera after mmi update q7
Old 02-07-2016, 04:37 AM
sejo sejovic's Avatar
Default no rear view camera after mmi update q7
Hi, after i updated my mmi i lost the*rear*viewcamera*and also the parking sensors.. I went into hidden green menu and enablled them, but still nothing :/*
Is there any way i can retrieve this using vag-com? The reason i updated is because i was stupid and pressed bootloader :/ I then bought genuine original update discs (5570) and mmi is working. After update, no*camera*and no park sensors and no air suspension menu.*
I retrieved air suspension via vag-com but on the picture it does not show q7 but i think its a a8 or a6? Any help is HUUGE apiritiated!!
Thanks in advance*
q7 2007 3.0 s line fully speced
Old 02-10-2016, 07:02 AM
iaflyer's Avatar
Did you reset the MMI after the update (3 button reset)?
If you have access to a VAGCOM or VCDS, you can scan the car and see what modules show up. My suspicion is that the Information Electronics (5F) module turned off the rear camera so it got deactivated somehow. If you scan the car and don't see the module, you'll need to go into the Inform. Electronics and turn on the rear camera.
I added a Rear view camera in my 2010 A6, and didn't see the camera module until I turned it on in the Information Electronics. Might be different in your car though.
pelletman
65
07-21-2021 09:49 AM
sejo sejovic
VAG-COM Discussion
02-06-2016 05:01 PM
537playing
VAG-COM Discussion
05-10-2014 07:11 PM
STEALTH_6
06-28-2007 12:28 PM
Bena6
VAG-COM Discussion
06-01-2006 01:21 PM
Quick Reply: no rear view camera after mmi update q7
