Part IDs for RNS-E retrofit
Hello!
I have a Audi C5 and I ordered a harness to be able to install RNS-E which replaces my RNS-D.
Works fine, but I'm missing the CAN L/H wires which I will install into the harness behind the instrument cluster and I want to do it as clean as possible.
So I would require some pins, I found these numbers:
000-979-018, 000-979-010 - are they the proper ones and/or are there other numbers too?
This is were it will get weird. Hope "clean as possible" explains my intensions.
For some reasons my car has BOSE and I ordered from KUFATEC a harness that fits me, but it is missing the 8-pin brown connector (Connector II).
Does anyone know a number for the lead or something that I could take appart and use it?
I'm talking about this one: Imgur: The most awesome images on the Internet
Will need pins too: N 103 361 05
And it gets weirder.
My RNS-D had the DWA-GND plug, that signals the alarm when removed.
Does anyone know any part IDs for the housing?
I was not able to find any information about the female housing neither about the pin.
I'm talking about this thing: Imgur: The most awesome images on the Internet
Also, there is a RFSL pin in the 26-pin connector. Is there any point in adding it to the RNS-E? From what I have read then RNS-E gets the reverse signal from CAN, so there is no benefit in adding this wire?
Any help will be appreciated!
I figured out the part about the lead (found that Symphony adapters are really cheap and they come with pins too).
Also found that the pins for CAN connector are 000-979-018.
At the RNS-E end I need N 905 844 05
But still confused about the alarm ground.
COMPUTEK::WMS
03-12-2007 04:26 PM
