Last edit by: IB Advertising
vSee related guides and technical advice from our community experts:
- Audi How to Use SD Card<br>Step by step instructions for do-it-yourself repairs.
SD Card and MMI
#81
+1...I reformatted my 64gb sd card to FAT and Audi now recognizes it
#82
How's the video quality? Anyone else try out video?
So I bought a 128GB card (Link below) and loaded more than 7,000 song and it worked great on my 2015 A3 MMI Navigation! Even plays movies in .m4v. Will try more video format and report back. Cheers!
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
#83
hi, has anyone overcome the limitations with number of music folders and/or files in the SD card? I had to delete a lot of music in order for MMI to recognise the artists beginning with "Z". Overall, I must say the MMI capabilities are below my expectations.
#84
how many tracks do you have? could be too high
as much as MMI isn't perfect, i've tried MB, BMW, and Audi, and I think Audi has the most usable system of all three
#86
It's hard to say since you don't list the year, model, and system type in your car. I'm pretty sure the manual for my '11 A4 with MMI lists the max as 4000 songs. The '13 and later MMI models had a higher limit, which I believe was per/folder.
I would think the answer would be in your owners manual.
#87
#89
Playlist Export Question
Just an FYI that I struggled with trying to do this for a couple of hours tonight and couldn't get it to work. Finally shelled out the $5 for the Playlist Export App (https://itunes.apple.com/us/app/id434426826?mt=12) and it worked!
This was for a 2010 S4.
One thing to note though is that the playlists were greyed out for a short period when I first loaded the card. The music would play (from the folders, not the playlists) and I was about to give up because I couldn't even click into the "Playlist" option, see terrible photo below.
But after a couple of minutes I went back and could access the Playlists and everything worked!
I saw that you used Playlist Export to get working playlists on your SD Card. I have been trying to make Playlist Export work for a couple of weeks with no luck so far. I always end up with a greyed out playlists folder, but all of the songs play with no problem directly. I am pretty sure that I have some program setting set the wrong way and wondered if you could provide some guidance on how you got it to work.
Thanks in advance!
John
2010 A5 Cabriolet
#90
Hi, the issue I have is that some songs (can't find any logical pattern) are greyed out. Not just from playlist, but when I go into the artist folder as well. My understanding is that SD card has no permission issue, so if I purchased in iTunes under my UK or US account, it should still work. I am using a 2015 / Q5. Any ideas?
thanks in advance
thanks in advance
