US to metric display using VAG
Hi,
I'm fairly new to the allroad... Got it last month.
I have a 2002 that came from California but I am in Canada.
I tried to switch the display by inputing the Canada code in "instrument" controller using VAG but the clock goes funky when I do this... Anybody had the same issue? It is ok when I go back to US.
Thanks
David
Thanks
David
Yes you can go back to US system, without problem. there is an issue with board and programming , this can be repaired, you are interested I can help you fix it
Thanks audifirst
I would be interested in a fix if it is not too hard... I went back to US spec for now and it works. Is it spmething that can be done with the VAG tool?
This process can not be done with vagtool, or any other tools, it is physical repair and programming process , I sent you PM
