ETKA diagram help: location(s) of G2 and G62 coolant temp sensors?
Old 08-07-2008, 05:07 AM
arob's Avatar
Default ETKA diagram help: location(s) of G2 and G62 coolant temp sensors?
I've got a barely noticeable rough idle, and my temp gauge is moving almost as fast as my tach (not that bad), and I'd like to replace before my road trip down to the Outer Banks next month.
Any help is appreciated.
Thanks!
Old 08-07-2008, 05:11 AM
absolutcq20v's Avatar
Default What's the page number?
The sender for the gauge, assuming it's like the A6/older 2.7, is $7 and takes 2 minutes to change (with limited spillage).
Why replace both? Vag the other one to see how it performs...get to it!
Old 08-07-2008, 05:16 AM
Member
bobster4's Avatar
APK knows where it is.
Old 08-07-2008, 05:32 AM
arob's Avatar
I dunno...and I don't have a VAG. This is from the first scan that Rog did pre-purchase.
Old 08-07-2008, 05:34 AM
apk-S4's Avatar
Default The temp sensor for the temp gauge is on the back of the passenger side of the engine
on the hard coolant line that connects the heads (basically right below the accordion hose). The one that the computer uses is down near the lower radiator hose.
DO NOT, UNDER ANY CIRCUMSTANCE, ASSUME THAT YOUR THERMOSTAT IS BAD. I'm just sayin...
BTDT...don't want to be that stupid again.
Old 08-07-2008, 05:35 AM
Did it throw particular codes? List prease.
Old 08-07-2008, 05:49 AM
arob's Avatar
Default Here is the initial scan
VAG-COM Version: Release 704.1
Data version: 20071016
Thursday,12,June,2008,18:25:39:13976
Chassis Type: 4B - Audi A6 C5
Scan: 01 02 03 06 08 15 16 17 18 34 35 36 37 45 55 56 57 65 67 75
76 77
VIN:
Address 01: Engine Labels: 078-907-551-AZA.LBL
Part No: 4Z7 907 551 L
Component: 2.7l V6/5VT G 0001
Coding: 06712
Shop #: WSC 40617
WA1YD64B82N040168 AUZ7Z0A1946544
2 Faults Found:
17862 - Exhaust Gas Temp Sensor 1 (G235): Short to Ground
P1454 - 35-00 - -
18062 - Please check DTC Memory of Instrument Cluster
P1654 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes
No fault code found.
Address 06: Seat Mem. Pass
Address 08: Auto HVAC Labels: None
Part No: 4B0 820 043 AD
Component: A6-Klimavollautomat 0105
Coding: 00010
Shop #: WSC 02325
2 Faults Found:
00785 - Temp Sensor in Instrument Panel (G56)
30-10 - Open or Short to Plus - Intermittent
01272 - Positioning Motor for Central Flap (V70)
41-10 - Blocked or No Voltage - Intermittent
Address 15: Airbags Labels: None
Part No: 4Z7 959 655 E
Component: Airbag 8.4E 3000
Coding: 0000307
Shop #: WSC 02335
1 Fault Found:
01212 - Belt Tensioner Igniter; Rear Passenger Side (N197)
001 - Upper Limit Exceeded - Intermittent
Address 16: Steering wheel Labels:
Address 17: Instruments Labels: 4B0-920-xxx-17.LBL
Part No: 4B0 920 981 P
Component: KOMBI+WEGFAHRS. VDO D07
Coding: 06264
Shop #: WSC 06117
1 Fault Found:
01039 - Coolant Temperature Sensor (G2)
Address 34: Level Control Labels:
Address 35: Centr. Locks Labels:
5 Faults Found:
(typical door alarms)
Address 36: Seat Mem. Drvr Labels: None
Part No: 4B0 959 760 B
Component: Sitzmemory R1 F 0101
Coding: 00001
Shop #: WSC 00000
1 Fault Found:
01446 - Sensor for Driver Seat; Seatback Adjust (G230)
20-00 - Malfunction in Basic Setting
Address 45: Inter. Monitor Labels: None
Address 55: Xenon Range Labels:
Address 56: Radio Labels: None
Address 65: Tire Pressure Labels:
Address 76: Park Assist Labels:
End --------------------------------------------------------------------------------------------------
Old 08-07-2008, 05:53 AM
Member
bobster4's Avatar
See, told ya he knew where it was. :P
Old 08-07-2008, 06:38 AM
nadrealista's Avatar
I would check the contacts first
Old 08-07-2008, 06:41 AM
Default I would take care of that EGT before trip
it can cause some drivebility issues
Quick Reply: ETKA diagram help: location(s) of G2 and G62 coolant temp sensors?
