Add a custom Q5 MMI splashscreen
As an Q5 owner, I figured I'd cross-post this in the appropriate forum...
https://www.audiworld.com/forums/a6-.../#post24839599
Basically you can create and install your own custom MMI splashscreen instead of one of the stock ones. I performed this on my Q5 and it worked great.
https://www.audiworld.com/forums/a6-.../#post24840031
AudiWorld Expert
Thanks.
The link title is a bit misleading. From reading this, it sounds like you don't actually need Vag-Com (VCDS) to perform this. All it takes is just a script file and image file that need to be placed on the SD card. Correct?
I agree, the title is somewhat misleading but it's my own fault as I sort of hi-jacked the thread in the other forum. This could almost use its own thread. But to answer your question - just a custom splash screen image and an SD card with the other appropriate files on it.
It's actually a pretty easy hack and as long as the IMG file is the correct parameters, you are good to go.
NJRickD
08-15-2005 03:29 PM
kenny (dremel)
01-05-2004 07:24 AM
Flyboy
09-20-2003 07:41 AM
