Audi Q5 Tire Recommendation
#11
Surprising amount of mpg difference. Do you regularly check the inflation of your tires? And have you checked to see if the new ones are perhaps overinflated to help give better mileage?
Tire buying would be so much simpler (or at least, more logical) if we could only test drive the damned things.
#12
Would Plus/Oversizing work for the OEM 5 Spoke? With OEM as 235/55/19 to 255/50/19 I believe the stock is 235/55R19 102V 8Jx19 ET39 5x112 M14 x 1.5 66.6 2.3
#13
I am very happy with my current set of Continental DWS Extreme Contact tires. Most of my driving is highway driving, but go up to the mountains a few times a year. I am almost ready for a new set and have 54,000 miles on this set, so I think I got my money's worth.
I hear they have a new version of this tire available (DSW 06). Not sure what the difference is, but I think I'll go that route.
And for reference, I inflate to 38 PSI (cold) all around, and check weekly. I believe the door says 34, but I like a little extra air for a little better performance and tire life. No, I don't fill with Nitrogen, I just don't see the point.
OEM 20" (S-Line) tire size (I'd have to look up the actual size).
#14
AudiWorld Expert
But 255/50/19 - yes. People have done this before:
https://www.audiworld.com/forums/q5-.../#post24645646
#15
Nitrogen is a good thing, although it is dirt cheap and what some places charge for it is ludicrous. Argon is even better--but that's expensive.
Funny thing is, plain air is about 80% nitrogen, 20% oxygen, and because the oxygen molecules are smaller, the oxygen leaks out of the tire first. So maybe your tire drops 4psi and that's almost all oxygen coming out. You add more air, and you've got what, 85%? 88%? nitrogen in the tire now, because of the oxygen--not air-- that leaked out. You repeat this a few times...and gee, you're practically running nitrogen anyway.
Black? Check. Round? Check. Four? Check.
I'm not running an F-18, that's been pretty much good enough for me.(G)
#16
I would hope they're better now, but mine have been terrible and I wouldn't recommend to anyone. No mileage difference for me, either, but that's all pretty much marketing anyway unless you happen to drive the exact perfect way for how they're designed (which I won't!). Hopefully you have better luck, I remember Tire Rack noticing that the compound wasn't as good after initial high marks, too, so it wasn't just me. Hopefully whatever Pirelli screwed up's been resolved, but I can't trust getting the same tire I've been hating.
I had my cruise control set on 104 mph last Monday coming back from Austin on some back country roads. After about 10 miles, I decided that was a bad idea and set it on 90 mph for the rest of the 2.5 hour trip.
A lowered Q5 just seems so smooth and capable at high speeds.
To stay on topic, my Goodyear Excellence tires that came with the car are about worn at 14,000 miles but I don't use the brakes much around corners.
#17
355/50/19? Umm... no.
Thanks
#18
#19
I've heard tell of some guy with a non-lowered TDI that's had it up to 110 and thought the handling was just fine, too.
Finally someone who beats me! I get 20-25K out of any tire I've ever had, no matter what type. I ran Toyo T1-S max summers on my Passat Wagon because they had insane grip in all conditions and wore exactly as fast as a normal Michelin all-season (so it's not like I was getting 10-15K vs. 40-60K, but I believe 20K vs. 20K).
imdakine1
Q5/SQ5 MKI (8R) Discussion
05-12-2018 09:38 AM
bugbehr
13
06-04-2013 07:52 AM
hemant
9
02-17-2006 09:04 AM
DJMattFresh
12-05-2000 09:07 PM
