Audi SQ5 vs modified 3.0 Q5
#11
I believe there are substantially more engine parts which also differentiate the SQ from the 3.0T. I remember when we got our 3.0T, I was excited, figuring we could (down the line) tune it to approximate the SQ. But, not really. At least not reliably, considering the many more substantial parts the SQ gets.
#12
Maybe they reinforce the block externally at assembly. Everything I've read says the block is stiffer. For example, from an article in Motor Authority
Fundamentally, the 3.0-liter supercharged V-6 follows the same design as that in the Q5 3.0T. Yet in case you're wondering, you can't simply 'chip' a Q5 3.0T and arrive at an SQ5; there are plenty of serious upgrades in the SQ5. Compared to the existing supercharged V-6 of the same displacement in Q5 3.0T models, the engine in the SQ5 has a stronger crank, stiffer block, and different intake and exhaust manifolds. Brakes have been upgraded—both with bigger rotors and calipers and with a stronger brake booster—and engine cooling capacity has been raised. To work with that, there's a larger front end, for more airflow under the hood (that, plus wider tires actually make its coefficient of drag a bit higher).
#14
At a base price of $51,900, the SQ5 is a little over $3,000 more than the equivalent Q5. Why the premium? To start, there’s the engine. Essentially this is an S4/S5 spec 3.0 TFSI and as such benefits from an uprated crankshaft, bearings and stiffened engine block. The SQ5 also gets a new sport exhaust from manifold to valved pipes at the back, not to mention increased cooling capacity that allowed engineers to up boost and thus up power beyond that of the S4 and S5. Even still, the SQ5 retains the Q5’s class-leading towing capacity of 4400 lbs.
#15
No one seems to have been able to prove the SQ5 engine is any different than 3.0T, despite audi vaguely leading the media to believe they're different. What the SQ5 does have over the 3.0T is quite a lot, but you also pay about $8k for it. I think it's well worth it:
-much nicer interior: upgraded steering wheel, leather, trim options, and gauge cluster
-better front brakes
-sports suspension (although no adjustable dampers)
-factory OEM engine tune with warranty is more powerful than aftermarket stage 1 tune for 3.0T
-Tuned sport transmission similar to a DCT/DSG.
-nice exhaust for OEM including quad tips that make more noise than average
-improved engine/induction noise (fake, but sounds authentic and nice, and can be turned off)
-exterior looks enhancements
-upgraded wheels
-more exclusive
If we negate the engine power and tunability issue, comparing a family member of mine who has a Q5 3.0T S-line, my SQ5 looks much more upscale inside and out.
I honestly see about an $8-10k difference. A Q5 3.0T PP is about $52k with options. An equivalent SQ5 is $60k. Base price to base price they are $44,900 vs $52,700.
-upgraded wheels
-more exclusive
#16
I wrote that the engine is the same.
And the compressor is the same on the SQ5 and Q5
Of course there are differences such on SQ5 has an extra radiator ,different absorbers but the engine is the same.
Good luck
Additional cooler
Compressor
#17
-upgraded wheels
-more exclusive
-upgraded wheels
-more exclusive
#18
I'm not saying the blocks are different. Your catalog cut sheets show that. What I'm suggesting is that reinforcing gussets or plates may be installed at a higher assembly level...along with a slightly smaller pulley on the supercharger.
I think you are suggesting that the finished engine is the same for the Q5 and the SQ5 with the only difference being the tune. Does the catalog you keep referring to show the next higher assemblies?
You believe what says Motor Authority. I believe what says Audi catalog, they are relevant to me
Good luck
Additional cooler
Compressor
Good luck
Additional cooler
Compressor
#19
Ample evidence of the same engine but you do not want to accept
I think it's enough, end for me
#20
Hello Spijun,
Quick question. The options sticker on my 2013 3.0T P+ has different codes for the brakes than what you are showing. Front - 1LE and the rear - 2EL. I haven't had them apart but the fronts look like a dual piston, is this correct for 1LE?
Here's a pic of the front
Thanks,
