Help - thoughts on things I might check?
I've got about 65k miles on my ride and I'm constantly getting these codes.
Car runs fine. No noticeable differences.
OBD2 - confirmed:
P2187 - System Too Lean at Idle Bank 1
OBD2 - pending:
P2279 - Intake Air System Leak
OBD2 - permanent:
Engine:
P160E
P1009 - Mass air flow (MAF) sensor 1/2, implausible signal from load detection
OBD2 - confirmed:
OBD2 - pending:
OBD2 - permanent:
Engine:
P160E
OBD2 - confirmed:
OBD2 - pending:
OBD2 - permanent:
Engine:
P160E
OBD2 - confirmed:
OBD2 - pending:
OBD2 - permanent:
Engine:
P160E
Shouldn't be a major repair based on my experience. Worst leak I ever had actually was a hole in the intake manifold, but it was a simple patch to fix it. Finding the dang thing was the tough part.
If that doesn't work, try cleaning your MAF sensor next (might have 2 of them, I'm not 100% sure though). If that doesn't work I would replace the MAF(s). The reason it runs a lean code is because the MAF isn't reporting the right amount of air coming in through the throttle body, and therefore the car is getting more air than the MAF recognizes (as when it's dirty), and that is exactly what a lean condition is. The leak post MAF sounds more likely to me though.
KEVOZS8
06-09-2009 05:54 AM
Barry in Utah
A4 (B7 Platform) Discussion
09-24-2008 12:48 PM
S4Ca$hwhore
03-20-2006 03:12 PM
