Hot Air not blowing inside the cabin
The air blowing inside the cabin of my 2011 Audi Q5 is not hot, it does blow some hot air but not enough to warm someone. The engine temp reaches almost half of the mark ( needle is one line before the middle) and the temperature stays there all the time. Turn the fan inside to start blowing hot air and nothing changes much as I am increasing the temp, 75, 80, 81 and finally hi.... it does blow air (not as much as it used to) but not hot enough.
Any ideas as what might be wrong? Last I was at dealership was for 15k service and everything looked fine..
Sorry I didnt respond to this thread sooner.. I didnt have access to my computer..
So I did a little more observation and it seems like it's just the middle blow vents that does not blow air.. the driver and passenger sides seems to be fine? Also, if I turn ON windshield de-fogger (not sure what's it called!), it seems to be blow hot air.. as I expect.. I could hear the fan blower loud earlier (when everything was working fine) as I increased temperature and now I could hardly hear blower fan even when I raise the temperature.. so after all my heat "system" might be working fine, it might be just the fan in the central blow vent?
I think hot air won't go out of rear center vents, as it does not go out of front center vents. Cabin is heated by using vents closer to the floor. You will feel stream of cold air from center vents in summer.
I think my main concern is blower/fan would get louder as I increased the temperature but now I could hardly hear fan/blower even at high temp (80F). Sorry if my post is confusing and seems to be changing on what's the issue.. We just completed a 300 mile trip and it seems like cabin was getting warm but not as fast.. so I do suspect something is wrong and its not working "as good" as it was earlier..
I have same issue, my driver door vent and middle driver side blows hot air, passenger middle vent and passenger driver door blows cold air. Even at the bottom passenger as well. Any suggestion? I check coolant is full, I check the heater actuator door, it spins when adjust the **** as well.
