Rear hatch button problem/solution...
Old 01-12-2010, 06:12 AM
HaveBullDogWillTravel's Avatar
Default Rear hatch button problem/solution...
It all started with a call from the wife. She was a little panicked in that the rear hatch would not close when she pressed the button...and it was raining. UGH! I told her to just grab the hatch and pull down and force it shut. She did with more effort than she thought it would/should take...but it closed. When I got home that night I messed around with opening and closing the hatch for a bit and discovered that the close button on the hatch would stick if pressed on the left side of the button. If pressed on the right it worked fine. Once the button sticks the door will NOT close unless manually forced to the closed position. Tapping on the button will release it from the stuck position. So it looks like I'll be needing a new button at first service time. No biggee. One problem that did come up was that now the hatch would not open all the way. After a bit of searching I found out(on the Q7 forum) the way to reset the rear hatch is to open it and then manually push it to the desired height and then press the button[on the right side for me ] for 5 seconds. The hatch will now open to this "set" position. I hope this helps someone with the same issue.
[IMG]<img src="http://i131.photobucket.com/albums/p315/hoscarnag/roadflypix/button.jpg">[/IMG]
Old 01-12-2010, 08:34 AM
guyguyke's Avatar
why not simply press the center of the button ?
Old 01-12-2010, 09:58 AM
Default Good Question...
Pressing the center resulted in sometimes working, sometimes sticking.
I should have included a "maybe" note on the pic...sorry
Old 01-12-2010, 10:58 AM
solucien's Avatar
Cool, good to know too that the hatch has a 'memory'.
Can come in real handy if there's a load on the roof like long skibox or surfboards
Old 12-29-2013, 11:01 AM
AllroadIII's Avatar
Default Thanks! You saved me a trip to the dealer.
I had the problem of the hatch lid not opening all the way as well and saw your post, tried it and it worked. Now the hatch lid opens all the way like it should.
Old 12-29-2013, 11:45 AM
spijun's Avatar
Audi Q5 Power Tailgate Trick
Old 12-29-2013, 03:10 PM
m1964's Avatar
It all started with a call from the wife. She was a little panicked in that the rear hatch would not close when she pressed the button...and it was raining. UGH! I told her to just grab the hatch and pull down and force it shut. She did with more effort than she thought it would/should take...but it closed. When I got home that night I messed around with opening and closing the hatch for a bit and discovered that the close button on the hatch would stick if pressed on the left side of the button. If pressed on the right it worked fine. Once the button sticks the door will NOT close unless manually forced to the closed position. Tapping on the button will release it from the stuck position. So it looks like I'll be needing a new button at first service time...
you may try "electrical contacts lubricant" spray from radioShack - they have "cleaner" and "lubricant", and I had buttons sticking in my RX350 I thought I had to go the dealer but the lubricant spray fixed the problem.
Just spray around the edges of the button.
Old 12-30-2013, 03:55 AM
soonerfan's Avatar
Audi Q5 Power Tailgate Trick - YouTube
Spijun, you are a veritable font of useful information and I am very glad we have you on this forum as a reliable and trustworthy contributor. Thank you for your attention and Happy New Year to you as well.....and I see nothing wrong with your English, BTW.
Old 12-30-2013, 04:40 AM
spijun's Avatar
Thank you and all the best
bozack
Q7 MK 1 Discussion
02-16-2022 08:06 PM
spindlewood
Q5/SQ5 MKII Discussion
09-11-2018 07:04 PM
Delusory
04-30-2016 01:15 PM
eldoj
Q7 MK 1 Discussion
10
06-06-2011 08:21 AM
MarkItZero
Q7 MK 1 Discussion
12-27-2006 09:22 AM
Quick Reply: Rear hatch button problem/solution...
