Undercarriage Panel Loose??
Old 07-26-2014, 11:17 AM
Jazzy's Avatar
Default Undercarriage Panel Loose??
Today after turning off the Q5 (just like any other day), I heard what sounded like air brakes releasing; " Psstcchhhhh... "
I took a moment to see if it happened again and it did. A quick look under the car tells the tale... water dripping onto the hot exhaust pipes (BLUE arrows) which I assume is from the A/C but they are coming from several locations -- is that normal?
Then I noticed the panel. The pic is from the passenger side looking up underneath at the panel. It has come detached; you can see the screws are missing/fallen out (RED arrows).
I also noticed the left and right side panels (where there is a seam) have a greasy substance all over the area (GREEN arrows).
It seems there's a lot of "stuff" going on in this immediate area that doesn't look right. I'm not mechanically inclined so I'm not going to even try to guess what's normal and what's not.
The obvious next step is a trip to the dealer, but I thought I'd post in here to see what sort of comments I can get from you guys examining the photo!
Please let me know your thoughts -- thanks!
RED = Panel screws missing
GREEN = Heavy grease areas
BLUE = Water drip locations
Old 07-28-2014, 02:58 AM
Jazzy's Avatar
Ok; no comments?
Would anyone be willing to take a look under theirs and see if they have the same sort of water exits and grease on the flanks there (GREEN arrows), please?
I'd like to have some talking points before I take her in.
Old 07-28-2014, 03:39 AM
Telate's Avatar
I don't remember seeing anything when I rebuilt my car 1.5 years ago...In fact, I don't recall seeing anything but brake lines under that cover that has grease on it. The one thats hanging down the clips could easily fall out if they aren't tightened all the way - its only like 1/2 turn to put them in.
Old 07-29-2014, 04:35 AM
AudiQ5sleeper's Avatar
air swooshing sound. did you apply the e brake? if you did thats where the sound is coming from. if not then something is wrong
Old 07-29-2014, 07:23 AM
SQive's Avatar
Don't worry about the water. If you run the air-con you're going to get condensation at several different places if it's humid where you are.
I can't see where the grease could be coming from. Clean and recheck it later.
As for those two bolts, take it back to whoever changed the oil last time and point it out. They should be happy to replace them, quietly, to cover such a simple mistake.
Old 07-29-2014, 10:30 AM
Telate's Avatar
There is no reason to undo those bolts in the first place. There is a front cover and a rear cover. The one in question covers the crossbrace and tranny. The engine cover is joined to this piece by three screw on the opposite side.
Farragone
S4 (B8 Platform) Discussion
02-26-2013 03:37 PM
Swank4
06-05-2006 09:15 AM
B4turbo
13
01-26-2004 09:54 AM
a4b5
02-20-2003 11:33 AM
YosemyTT
15
02-12-2002 05:46 AM
Quick Reply: Undercarriage Panel Loose??
