New Audi Question...break-in period required?
I just ordered an Audi SQ5, and I've never owned an Audi before. When new, do they require a break-in period for the engine. Is there a certain RPM not to exceed for a set amount of miles? I know that many American vehicle say there's no break-in required now-days. But my father bought a Porsche earlier this year, and the Porsche manual was very specific to keep the engine RPM under 4000 RPM for the first 2000 miles. So I was wondering about the Audi in this regard.
Great question! Thanks for asking it. My Q5 (TDI) is scheduled for delivery next month, it's also my first Audi, and I too wonder about whether a break-in period is required and if so, what the guidelines are for how one should go about that. I'll be curious to read the replies.
Congrats on your SQ5 order!
My dealer told me that the rings are already seated. The break-in period is for the tranny. He just said to not use sport-mode and try to keep it under 5K RPM until after 500 miles...for what it's worth.
I've always felt that Audi, which has spent millions of dollars on engine research and development over dozens of years is probably the best source for accurate break-in advice. Hence, I've always followed the recommendations as found in the car's manual.
AudiWorld Expert
" The engine needs to be run-in during the first 1,000 miles.
For the first 600 miles:
-Do not use full throttle.
-Do not drive at engine speeds that are more than 2/3 of the maximum permitted RPM.
From 600 to 1,000 miles:
-Speeds can gradually be increased to the maximum permissible road or engine speed.
During and after break-in period:
-Do not rev the engine up to high speeds when it is cold. This applies whether the transmission is in N(Neutral) or in gear.
After break-in period:
-Do not exceed maximum engine speed under any circumstances.
-Upshifting into next higher gear before reaching red area at the end of the tachometer scale.
During the first few hours of driving, the engine's internal friction is higher than later when all the moving parts have been broken in. How well this break-in process is done depends to a considerable extent on the way the vehicle is driven during the first 1,000 miles."
+1 on snagitseven's feedback. What manual says:
(at least as of 2013). First 600 miles, take it easy and don't exceed ⅔ or max RPM. Thus, per the earlier Porsche reference, for a gas motor around 4000 rpm max. Assuming it still says the same, adjust RPM downward for TDI's.
Then from 600 to 1000 miles, gradually increase (their italics) to full performance use as needed. Separately, they say take it easy on the brakes for the first 250 miles; that's also a decent recommendation for any new brake and rotor set, or tires for that matter.
Having even done it in Germany with the Q5 on Euro delivery, it wasn't that hard with an 8 speed since it has lots of gears to shift up to anyway. A little harder to be 100% sure w/ the Hybrid that uniquely has no tach, but I could do it by sound/feel pretty easily.
Somewhat unsaid, but not a great idea to tow anything substantial until it is broken in a bit.
Yeah, the 8 speed almost makes it difficult to get it higher than 2/3 of the tachometer unless your in Sport mode. Naturally the transmission will shift gears and keep the revs rather low.
My Q has a little over 4k on its TDI engine and transmission. I am definitely noticing a difference in the engine now that it has become broken-in. It seems stronger than it did initially. The torque has become more pronounced in the last 1,000 miles.
For its first oil change and service they recommend 5,000 miles or 1 year, but I contacted AoA and they stated that they recommend its first service window to open as early as 4,500 miles. So if your eager to have your first service, you should probably keep it within that window and not jump the gun. Then it's every 10,000 miles there after.
https://www.audiworld.com/forums/q5-.../#post24602650
