Parts to replace when doing brakes on 2012 Q5
I'm replacing the brakes, front and rear, on a 2012 Audi Q5 and I'm having trouble making sure I have all the right little parts I need to replace each time. Other than the pads and rotors themselves, does anyone have a complete list of the parts and part numbers so that I can order them?
This is what I have so far:
Fronts:
Caliper bolt
Count = 4 (two per wheel)
Diagram = 4
Torque = 30 Nm
Audi Part = 8K0-698-135-A?
Pad sensor (if tripped)
Count = 1 (driver side only)
Audi Part = 8K0-615-121
Rears:
Caliper bolt
Diagram = 4
Torque = 35 Nm
Audi Part = 8K0-698-470-A?
Question: Is the guide pin that this bolts into replaceable? If so, what is the part number for that?
Pad retainer clip
Diagram = 10
Audi Part = ?
Caliper bolt (if replacing rotors)
Diagram = 16/17
Torque = 100 Nm + 90 degrees
Audi Part = ?
Am I missing anything that needs to be replaced? Anyone have the correct / missing part numbers?
Fronts:
Caliper bolt
Diagram = 4
Torque = 30 Nm
Rears:
Caliper bolt
Diagram = 4
Torque = 35 Nm
Pad retainer clip
Diagram = 10
Audi Part = ?
Diagram = 16/17
Audi Part = ?
Fronts:
Caliper bolt
Diagram = 4
Torque = 30 Nm
Rears:
Caliper bolt
Diagram = 4
Torque = 35 Nm
Pad retainer clip
Diagram = 10
Audi Part = ?
Diagram = 16/17
Audi Part = ?
Fronts:
Caliper bolt
Diagram = 4
Torque = 30 Nm
Rears:
Caliper bolt
Diagram = 4
Torque = 35 Nm
Pad retainer clip
Diagram = 10
Audi Part = ?
Diagram = 16/17
Audi Part = ?
Anyone have the bolt part numbers and torques?
TRW-GIRLING, rear, 300X12MM
https://www.etka.me/Audi/USA/AQ5/201...R/6/615/615060
TRW-GIRLING, rear, 330X22MM
https://www.etka.me/Audi/USA/AQ5/201...R/6/615/615070
Here:
Here:
And especially how do I do so without taking them off the car to look for numbers. I'm trying to avoid additional work and replacing bolts just to check the size if I can.
1KW, 2EK - 300mm
1KE , 2EL - 330mm
FYI: 2.0TFSI - 300mmm
3.0TFSI and 3.0TDI - 330mm
RSTPerformanceRacing
07-12-2007 12:31 PM
slightly disgruntled
01-23-2007 07:21 PM
big_anthoiny
10
12-05-2006 02:39 PM
Jim Will
12-28-2003 09:08 AM
