Q5 diffs
#11
As a precursor - I have very little idea of diffs, but I remember reading that the engine in at least the 3.0 TDI is mounted at 90 degrees to the normal and then was reading this "introduction to Quattro" type article and it starts talking about the diffs used in this rotated mounted engines and I thought it might be of interest/relevance.
https://www.carwow.co.uk/blog/audi-q...stem-explained
#12
#14
Got this reply from Audi:
"I have received the following response from our Technical Support Team.
Anything with a longitudinally mounted engine uses a Torsen system (Audi A4 upwards); however, we no longer refer to it as
Torsen. Its official name is a Self-locking Centre Differential with Asymmetric Distribution of Torque – Torsen is an older
generation system. Our quattro system is now far more advanced.
To answer the question, the new Audi Q5 (and other MLB products) do not use the Crown Gear system, unless it’s an Audi RS 5.
Technical Support recommends you book a test drive, as the quattro system is hugely capable and something you should experience
first-hand, especially if it is raining or there are wet leaves on the road. You will experience an immediate benefit over cars
with only two driven wheels.
This system splits torque 60 per cent rear and 40 per cent front by default in normal conditions for better driving dynamics,
but then up to 85 per cent of the power can be sent to the rears if it detects wheel-spin at the front. There is also an option
(standard in some higher-powered models - please refer to the price list for this) of a Rear Sports Differential. This is for
Torsen cars and it effectively distributes power to the outside rear wheel when cornering. This effectively “drives” the car
round a corner, eliminating under steer – again we would recommend that you book a test drive at your nearest Audi Centre to
experience this technology first hand."
So there we go!
Thanks all for your help,
Puns
So there we go!
Puns
Bahn S4
Southeast Discussion
11-14-2005 11:16 AM
Mattsaudi
11
04-04-2005 09:42 AM
Generic
03-18-2005 07:49 AM
vegasS4
02-02-2002 07:50 PM
