2011 Q5 Sway Bar Bushings
Old 06-20-2014, 06:23 AM
Telate's Avatar
Default 2011 Q5 Sway Bar Bushings
Hi,
I was wondering if anyone has changed these yet, is it just a simple jack up the car, unbolt the bracket, and change the bushing?
My car has this nice creak whenever I brake, speed up, or turn a corner and after 3 months it is driving me insane. Due to the fact that it does it speeding up from a stop and braking, I am leaning towards sway bar (it does not creak if you rock the car side to side or front/back by hand, only while driving). I figure the bushings are cheaper than an endlink so I'm starting with those
Old 06-20-2014, 07:23 AM
rdA4WtQ5's Avatar
Spray them with silicone first to identify the problem. May even fix it permanently.
Old 06-20-2014, 07:26 AM
AudiQ5sleeper's Avatar
Originally Posted by Telate
Hi,
my rear strust were blown. you may check them as well.
Old 06-20-2014, 08:33 AM
Telate's Avatar
I've tried lubricating...nothing I spray in the front works. I know the sound is coming from the driver's front. I can't see it being a shock/stut as you would hear that when shaking the car by hand. The silicone may have calmed it down a bit, but it is bad enough that I didn't really notice (I did have one time that I sprayed every damn bushing I could find on that side and it calmed down a lot for around a week).
Old 06-20-2014, 10:58 AM
did you find a place that sells the bushing?
Old 06-20-2014, 12:36 PM
RobC's Avatar
Audi part numbers for the front sway bar bushing:
4D0 411 327 H (FWD)
8K0 411 327 C (Quattro)
Old 06-20-2014, 02:16 PM
4D0 411 327 H (FWD)
what about rear?
Eden Frias (05-02-2023)
Old 06-20-2014, 07:58 PM
RobC's Avatar
ETKA doesn't list the rear sway bar bushing and bracket (no p/n) separately. Maybe the bushings come with the bar?
Old 06-21-2014, 05:14 AM
Telate's Avatar
4D0 411 327 H (FWD)
Well that is odd...the 8K0 bushing is almost impossible to find online, but the 4D0 bushing is everywhere. ECS tuning even has the 4D0 bushing listed as for the Audi Quattro 2.0. Is there even any difference between the two or is it just one of those give it a different part number and charge more things?
Old 06-21-2014, 06:11 AM
spijun's Avatar
Here 8K0.............
http://www.ecstuning.com/ES450638/
http://www.jimellisaudiparts.com/pro...K0411327C.html
http://www.vwpartsdept.com/OEMParts/...K0411327C.html
Differences between:4D0411327H and 8K0411327C
Quick Reply: 2011 Q5 Sway Bar Bushings
