20" rims comfort and durability?
AudiWorld Expert
Wow... it must have been 5+ years since I visited these forums...
Anyway, wife is looking into the Q5 3.0T. Those optional 20" titanium rims look nice, but I'm wondering how practical they are. Can you guys comment from a comfort as well as durability perspective? We have some pothole ridden roads around here, so I don't want to have to repair bent rims all the time.
If we buy it, I'll end up getting her a second set of smaller (18") rims/tires for winter, BTW.
I test drove the Q5 with 19's and 20's and for me personally, the 19's gave a better ride.
I've always thought that 19's were the perfect balance of large wheel looks and ride comfort. Mind you, that's been on cars...
With ADS
With ADS set to comfort, we find that the 20's ride very comfortably. On Dynamic, the ride is still relatively comfortable for a sporty vehicle, but you can definitely start feeling the road.
It also depends on the make/model of the tires used, side profile (how much meat they have), and if they are run-flat or not.
Some tire brands use a harder compound; a "thin" tire has less cushion and may feel harsher; run-flat tires ride firmer than conventional tires.
the bigger the size on rims the thinner the tires will get. they all will be using low profile tires. less meat on the tires you will hear more road noise and harsher ride.
Effects of Upsized Wheels and Tires Tested - Tech Dept. - Car and Driver
AudiWorld Expert
But David above has a point, too. Different tire models, even in the same size, will feel more comfy or harder, depending on rubber compounds used and how reinforced the sidewalls are. I remember using various 225/45/17 tires on my old A4. Bridgestone S03 were rock hard, to the point where tire installers had a heck of a time trying to mount/dismount them from rims. By comparison, ContiSportContact2 where very plush. They did not tramline anywhere near as much either.
Still debating which size to go with on the new Q5, but will most likely stick with 235/55/19. It's more a truck than it is a sports car, and it will be treated as such, so I want it to have more rubber between the rim and the road. Alas, I might change my mind over time... The factory 19" 5 double-spoke rims are kind of blah...
That's true if you're talking about the exact same tire model in two different sizes.
as for mounting low profiles. they are a pain to do. ive seen my friends dismounting and mounting low profile tires on my rims.
AudiWorld Expert
However, my wife's current C300 sport has 225/45/17 tires, and due to that fact, the steering is very responsive, and she wants to not lose too much of that responsiveness when moving to the Q5, alas, it's a frigging truck, so you can't have it all. And she passed on the Macan due to less room and cargo space.
AudiWorld Expert
