Smells like gym socks when running A/C
#11
Just to give everyone an update, I did use the Klima Cleaner that Rob recommended.
Basically I pulled the front vents out using a tool with a hook on the end. That revealed an air diffuser that appeared to be built into the center console. As I didn't want to pull out the stereo, etc. I just drilled a tiny hold in the left (drivers) side of the diffuser to fit the hose for the Klima Cleaner. Emptied the entire bottle and ran the heater on high for 10 minutes.
Put everything back together and the problem is solved.
Thanks to everyone for their help.
Brian
Brian
#12
Great suggestions if you already have the problem.
Some things that help to prevent the problem in the first place are to remove any debris right away before it finds its way in there, every last bit. And to turn off the A/C a few miles short of your destination if you can to dry things out. Sometimes it's just too hot for that one.
#13
I have tried many times to correct the same problem. Mine's not under warranty, so that's not a help. The smell is so bad and it keeps coming back after I try to get rid of it because it's so humid down here in Houston.
I will try Brian's remedy...if I can stand to work in the heat for a bit.
Thanks,
Jenn
Thanks,
Jenn
#14
Thanks,
Jenn
Thanks,
Jenn
#15
The smell WILL keep coming back, as long as there is organic matter in the vent system. You can "nuke" it, and the smell will go away, but then as new mildew grows on the crud it will come back.
I'm not sure if the cabin vents allow crud to come past the cabin air filter, or if the air filter may be part of the problem. What many dealers use is a product that is like shaving cream. You stick a nozzle into the evaporator drain tube (from under the car) and shoot the foam up into the evaporator, where the crud usually accumulates. The foam breaks it down and allows it to run out the drain, in theory leaving a clean system. If your drain hose is clogged (from insects or mud?) that can also be part of the problem.
Ozium is great stuff--but since it doesn't clean out the crud, the smell will always come back.
Once you've got it cleaned out, it can help to switch from AC to "scorch" to keep the system dry before you shut down. I'll sometimes put the system on highest heat, defrost vents only, and let it cook a the last few minutes on the way home. Yes it is uncomfortable, but only for the few minutes, and I know the system will be drier in humid weather.
This is not just a climate problem--it is a design flaw. Some car makers use antimicrobial materials in the vent system, some don't. That's just the start of "invisible" differences.
#16
AudiWorld Expert
And some car makers (Volvo, for example), run the fan for some time after you shut off the car to evaporate moisture from the system, so you don't have to switch AC off a few miles before you get to your destination and arrive sweaty.
TCU_TT
9
07-13-2007 05:34 AM
Sourdough Josh
03-07-2002 02:00 PM
