Front License Plate
Old 03-25-2014, 09:32 PM
hanyc42's Avatar
Default Front License Plate
Hello
I just recently received my plates and I do have the front license plate bracket... but the hole do not align with the holes on the license plate.
Is there a additional bracket or mount I need to buy? or Do I just need to drill holes into the bracket? It seems meaningless of having a front licence plate bracket if plates don't fit into them....
Thank you for the help in advance
Old 03-26-2014, 05:25 AM
Parsec's Avatar
Just drill the plate into the bracket. Better than drilling it into your painted bumper right?
Old 03-26-2014, 05:31 AM
Parsec's Avatar
Just to confirm, does your front bracket look like this:
http://boston.craigslist.org/gbs/ctd/4359300745.html
If it does then you just drill the plate into the bracket.
Old 03-26-2014, 09:15 AM
hanyc42's Avatar
Yes it's the same bracket.
I guess I will just have to drill the holes into them.
Old 03-26-2014, 03:23 PM
Redd's Avatar
Drilling is so 1950's. (G)
Buy a roll of exterior grade double-sided mounting tape, i.e. the gray tape from 3M sold at Home Depot, about 3 yards for $8. Clean both surfaces, be generous with the tape, give it 24 hours to cure the bond. That sucker's not coming off without some work.
No holes required.
Old 03-26-2014, 04:44 PM
Xenonista's Avatar
I don't think you need to drill anything, although a small guide hole might help. Just use self-tapping screws and drive them through the soft plastic.
Old 03-28-2014, 03:11 PM
arrtewwx's Avatar
Your dealer will possibly put the plates on free. Check with them, specially if you have reservations. It took them about 5 min and four screws to install mine.
QuincyQ7
Canadian Discussion
10-24-2023 08:06 AM
FuturaDesign
Q5/SQ5 MKI (8R) Discussion
01-24-2017 07:15 AM
sdr0303
02-01-2013 02:12 PM
RS4000
10-10-2007 02:26 PM
RedlumF
02-24-2003 07:49 PM
Quick Reply: Front License Plate
