10k miles interval between oil change?
Old 08-04-2011, 04:00 AM
  #11
loscoz's Avatar
without sounding silly tho' poking at the bees nest here ...
WHY would the Q's maintenance be scheduled for a 10K oil change IF not for then that is what is simply needed?
Changing oil every 4-5K was based on different 'quality' engines and non-synthetic oils.
If you followed the maintenance plan then have issues down the line wouldn't that fall back onto the manuf/dealership? (I know, I know, Prove it right??)
My husband and I have ALWAYS been under the thought that an oil change is 'cheap insurance' for maintaining a vehicle for a long life BUT we are under the AudiCare plan and have been following it of every 10K.
Do folks also follow that oil change intervals are also still in accordance with your driving of the Q (or any vehicle) i.e. sooner in heavy stop & go traffic vs. leisurely 'Sunday' drives?
Old 08-04-2011, 04:56 AM
  #12
The G Man's Avatar
Originally Posted by stevedusa
Got a follow up phone call from Audi today, asking how is the car doing.
I asked the service adviser and he said honestly he'd suggest a in-the-middle change (at 5k interval) and use good oil (full syn.).
Guess that's what I'll be doing.
Now there is a big surprise , thats like asking a BMW salesman if you should buy a BMW instead of a Audi. Unless you drive in servere conditions, there is no need to change your oil every 5000 miles. Of course old habits are hard to break, people in Europe have been doing 10000+ miles oil change interval for years. Many BMW owners have tested their oil at or near 10000 miles with good results.
Old 08-04-2011, 05:24 AM
  #13
Never Follows
Audirings4's Avatar
Not true. I've seen many tests to prove it. Not to mention the 1/2 qrt loss every 5k miles that is called "normal" by every service manger and service tech I've spoke to. That means your 2.0T will be down AT LEAST 1 qrt every 10k miles.
If you're ok with that than more power to you.
I agree with Loscoz... Cheap insurance.
I have always maintained my own car and believe a $35 Fully Synthetic oil change/filter every 5k is worth it.
Old 08-04-2011, 09:12 AM
  #14
The G Man's Avatar
Can you show me one test that shows European spec synthetic oil that have fail before 10000 miles under normal driving condition, not severe? I believe the Audi manual describe what is consider severe condition. If you can post that test, then Audi have a law suit on their hands.
If you are losing 1/2 quart of oil, you should probably top it off.
Its $35 if you DIY, but $100 at the dealership.
I am all for cheap insurance, but unnecessary maintenance is such a waste.
Old 08-04-2011, 11:38 AM
  #15
Never Follows
Audirings4's Avatar
Can you show me a test that states the vehicle was driven "severe" or moderate? Try to tell Audi that you drive your car like an 80 yr old grandmother and your car still burns oil. Prove it.
So you're telling us that if we can prove that our Audi's burn 1/2 quart oil for every 5k driven under moderate driving conditions then we could win a lawsuit against Audi? Wow, where did you pass the bar?
Read here.
http://tinyurl.com/3hg9y52
Common issue huh? Audi says it's normal. Good luck to anyone willing to fight them on it.
Cheap insurance is planning ahead and making sure oil isn't an issue.
I call a few quarts of oil cheaper than turbo or engines problems down the road.
Old 08-05-2011, 06:30 AM
  #16
The G Man's Avatar
10000 miles oil change interval have nothing to do with burning oil, I was simply stating that the oil is still good at 10000 miles under normal driving condition.
Most new engines burns oil because the piston ring is not seated right, the cylinder wall can also cause oil consumption. Sometimes when you drive your car like a grandma, it actually cause the piston rings to not seat properly. A little bit of oil consumption is normal for some turbocharged or supercharged engine and the Audi 2.0T have always had a problem with oil consumption.
Old 08-05-2011, 06:54 AM
  #17
uberwgn's Avatar
+1....and leads to issues down the road including high oil consumption.
Old 08-05-2011, 08:08 AM
  #18
edwyun's Avatar
Yes, especially with full synth as recommended by Audi. And with the Q5, under normal driving conditions, being at relatively low revs (e.g,. under 5K rpm), it should not be an issue.
The oil manufacturers and service dept's have you all worried!
Old 08-05-2011, 08:09 AM
  #19
edwyun's Avatar
+1
Old 08-05-2011, 09:19 AM
  #20
geronimosan's Avatar
I've seen all sorts of contradicting break-in period advice. I'm currently at 600 miles now - can someone please link to a valid and good break-in guide for the 2.0T engine to avoid the above mentioned problems?
Quick Reply: 10k miles interval between oil change?
