2.0T Timing Chain Tensioner
I recently purchased my first Audi, 2011 Q5 2.0T. I heard about the problems with timing chain tensioner failure. I currently have 117K on the engine and therefore became worried. Can anyone help me identify the early warning signs? What to listen for, etc before I damage the engine. When should the timing chain get replaced? Also, I did a little research online and I am not clear on the difference between the TSI and FSI engines. Any help would be appreciated. Thanks, sorry ahead of time if this has already been posted in AudiWorld, as I am new to AudiWorld.
A suggestion is maybe find a quality indepedent shop for repairs.
Here's the maintenance schedule for your Q5.
I did the work at my VW dealer as I have good relationship with them and I can negotiate the price better. All the parts are the same between the Q5 and the Passat (minus one or two). Total cost was $1800 per car if I remember correctly but I went a little crazy and replaced all three tensioners (lower, upper, oil pump), chains (lower, upper, oil pump), all chain guides, all bolts, the cover, and an extra serpentine belt. The failing tensioner itself is a $50 piece. If you only do the tensioner, I believe you can be under $900 at the VW dealer. Doing all tensioners, chains, and guides added more labor and of course part cost.
My Audi dealer quoted $2400+tax and I am not sure they were changing everything as I asked VW to do.
Thanks for the explanation. I will most likely play it safe as you did and replace everything that can wear. Best time is when it is all opened up. I replaced the timing belt on my Passat 2.6 several years ago, and like you I replaced everything. Thanks again.
By the way, keep your receipts. With the class action law suits going on right now about the tensioners failing, we may end up getting some money back in a few years...
Always save all receipts and record maintenance VW/Audi spec oil and OEM type filter used etc. Scan and keep on your phone.
Audi has been known to reimburse for catastrophic damage after a recall but not as good for preemptive updates.
