2016 Q5 left cockpit fuse box picture
Long and crazy story...I had to remove all of the fuses in the left cockpit fuse box and I didn't get to snap a picture before doing so. Could someone help me out and either send over a picture of theirs (2016) or the proper amp listing for the listed fuses? I need all three of the panels. Thank you in advance!
All should be listed in the back of the manual. But unless some prankster was fired, the manual lists the fuses from high number to low, while the racks are of course in opposite order, from low to high. (Or vice versa.) Just doublecheck the positions, by number.
Not all info is listed
Thank you for the reply. Unfortunately, my manual does not list amps needed. The list is there, in order, but I need what amp fuses correspond to the appropriate equipment.
If it helps, this is from a 2014 UK manual, extracted from a PDF:
Audi Q5 Self-help Fuses and bulbs Fuses
Left side of dash panel: Fuse carrier with plastic framesFig. 1 Left side of dash panel: Fuse carrier with plastic frames
Fuse position No.
Electrical equipment (circuit name)
# amps for fuse
Fuse carrier -A- (black)
Dynamic steering
ESC control unit
Pressure sensor (air conditioner), electro-mechanical parking brake, HomeLink, rear seat heating, automatic anti-dazzle interior mirror, air purity/outside air sensor, ESC switch
Camera for active lane assist
10
Sound actuator/exhaust sound system
15
Headlight range control/adaptive light
5/7.5
Headlights (adaptive light)
7.5
Control units (electro-mechanical parking brake, shock absorbers, quattro sport, towing bracket), DC-DC converter
Adaptive cruise control or high-voltage battery (hybrid drive)
5/7.5
10
Selector gate/clutch sensor
Side assist
Headlight range control, parking aid
Airbag
Rear wiper
15
15
Preliminary fuse (dash panel)
10
16
Preliminary fuse terminal 15 (engine equipment)
40
Fuse carrier -B- (brown)
Electric exhaust flap
5/10
Brake light sensor or sensor for brake pedal travel (hybrid drive)
Fuel pump
25
Power supply for AdBlue pumps, clutch sensor or brake servo (hybrid drive)
5/25
Seat heating (left-side) with/without seat ventilation
15/30
ESC
Horn
15
Door, front left (electric window, central locking, mirror, switches, lighting)
30
9
Wiper motor
30
10
ESC
25
11
Door, rear left (electric window, switches, lighting)
30
12
Rain and light sensor
Fuse carrier -C- (red)
Lumbar support
10
Dynamic steering
35
Climate-controlled cup holder
10
Windscreen washer system, headlight washer system
35
Control unit 1 for vehicle's electrical system
20
30
9
Panorama sun roof
20
10
30
11
Sun blind for panorama sun roof
20
12
Anti-theft alarm system
"A" is the leftmost rack, as you face them. Position 1 at the top, then counting down, which hopefully matches your manual. The fuse rating for each circuit should be the same, as the equipment is about the same as it was.
Or with any luck, someone with a 2016 can get you a picture.
Fuse position No.
# amps for fuse
Dynamic steering
ESC control unit
10
15
5/7.5
7.5
5/7.5
10
Side assist
Airbag
Rear wiper
15
15
10
16
40
5/10
Fuel pump
25
5/25
15/30
ESC
Horn
15
30
9
Wiper motor
30
10
ESC
25
11
30
12
Lumbar support
10
Dynamic steering
35
10
35
20
30
9
Panorama sun roof
20
10
30
11
20
12
Thank you Dr. !
That looks like it matches up with my manual. I don't like that they don't list the amps for the American documentation. They must not trust us :-) I'm going to give it a shot. As you said, maybe someone with a 2016 will still post a picture to double check. Thanks again.
Not that smart
Being a dumba**, in a hurry...our old Q7 was not easy to disconnect the battery in a hurry. I didn't have time to look into the new Q5. But thanks all for the replies. Looks like I am on the way to getting her back on the road. Now I think I'll lock up the spare keys.
Speaking of fuses. I've never known an ATO/ATC fuse to come loose from the usual socket, and never seen a "cover" like Audi uses to secure them in place. (And make them harder to remove.)
Is this becoming common practice? Some special reason here? Or just another Audi oddity?
2bflyin
02-01-2017 03:07 AM
Roque
11-13-2007 07:22 PM
stim141
12v V6 Discussion
12-01-2005 07:24 PM
brando
08-31-2003 01:32 PM
