Rear driver side door handle problem
Old 05-10-2014, 06:42 AM
bayridgeguy's Avatar
Default Rear driver side door handle problem
Folks, just seeking some advice or a brainstorming discussion which will hopefully explain the issue i recently started seeing with the car.
(The car has the intelligent key. )
If the car has been locked for a while and I unlock it, get in, start it, etc... When i attempt to open the rear driver side door from the outside - it appears as if the car is locked and doesn't open, even if the car is fully unlocked. In the meantime the other rear door opens fine. I can then make the door work by opening it from the inside and then the outside handle starts working fine even if that is the first door i try to open when the car is locked. The issue is only reproducible after the car has been locked for a while( i tried as soon as an hour after i locked it and was able to reproduce). However locking it with a key and immediately trying to reproduce doesn't reveal the issue.
Appreciate any pointers.
Old 05-10-2014, 06:12 PM
SeaBlue's Avatar
I noticed today mine (same door) wouldn't open either until I used the un-lock button on the drivers door.
edit: 2014 with smart key
Old 05-11-2014, 03:54 PM
Bad Andy's Avatar
Happened on my car. First the rear driver side door, then a few months later, the driver door. Ended up needing new lock/unlock motors on both doors.
Old 05-12-2014, 01:54 AM
Thanks. Was the issue easily reproducible when you brought it into the dealership or does this issue leave error codes? Or did the dealer just take your word for it and replaced the motors?
Old 05-12-2014, 10:26 AM
Cobalt Rain's Avatar
Hi BayRidge -
Search for some posts by me (I can’t find them right now) about intelligent key and cell phone proximity. My car exhibits several flakey behaviors like this when my cell phone is in the same pocket (or a close-by pocket). Move the phone, and everything is fixed!
Old 05-12-2014, 02:25 PM
Originally Posted by Cobalt Rain
Hi BayRidge -
That's nuts. I will try that next time the issue occurrs. I have yet to search for your posts but in my case when i pull the handle the blinker on the side-view mirror flashes as if it senses the key but i don't feel the door handle doing anything.
Old 05-13-2014, 03:17 PM
Bad Andy's Avatar
I don't have the intelligent key, just regular key and remote. Remote and interior switches would not activate the "lock-unlock" motors. Car has been out of warranty for some time. Dealer quoted me $ 750 per door. I had both doors done by an independent shop for $ 720. They used the genuine Audi parts (there are no aftermarket parts available).
alh3010
22
07-11-2022 01:32 PM
racheldela
Q5/SQ5 MKI (8R) Discussion
05-14-2020 11:10 AM
iBrant
08-29-2018 12:12 PM
audinatic
05-11-2004 02:13 PM
banger
Audi 100 / A6 (C4 Platform)
10-16-2001 04:32 PM
Quick Reply: Rear driver side door handle problem
